Old 03-16-2010, 10:36 AM   #5
Originally Posted by buffalogirl View Post
Thanks for your help! If it is the vent hose, wouldn't it smell all the time? Also, will I be able to see gas leaking from it? The car is only 3 years old, does the rubber normally break down/crack after that amount of time? It seems like it should have lasted longer, especially on a new car.
Is the smell stronger when you move the air supply knob to outside air instead of recirculate? If so, and with the smell being stronger with the car running, I would have the fuel system connections under the hood checked ASAP.
You can just pop the hood and see if there is a strong gas smell, or evidence of gas having been sprayed.
Two summers ago, one of my neighbors had his Buick go up in flames in the driveway. He had recently had it serviced and the mechanic failed to properly tighten the connection to the fuel rail after cleaning the injectors.
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Coolant Smell after sitting in hot sun? Snappy General Yaris / Vitz Discussion 3 05-31-2009 12:18 AM
Getting used to driving small cars... orangepeels General Yaris / Vitz Discussion 19 05-06-2009 12:45 PM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 05:26 PM
