Old 03-16-2010, 05:22 PM   #1
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Accurate fuel fill without topping off?
Traditionally, on my cars I've always had a standard procedure for ensuring an accurate fuel fill. Run the pump till it auto-stops. Top it off. Bounce 15 times. And then top off again. However:
1. Topping off results in increased pollution from vapor.
2. I've read on this forum that topping off the Yaris can cause problems with the canister/vent system. (Is this true, I wonder?)
3. Topping off the Yaris involves tediously putting in over a gallon of extra fuel, which takes a while and is a real pain in the cold and wind.
4. The way the filler is designed, it's hard to top off without getting fuel on the paint every time.
So... is there a better way to do this while preserving accuracy? I travel a lot, and so always using the same pump is not possible.
-Steve
sbergman27 is offline   Reply With Quote
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 326 02-15-2025 11:09 PM
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 03:35 PM
