Old 03-20-2010, 02:52 PM   #20
So, there's three terminals on the SPDT. I'm assuming I would keep the splice wire in the ground you told me before, cut it on the other end, add a female connector to the end, stick it in one of the terminals on the SPDT (assuming left or right one); find the chassis ground (wire?), splice a wire to it, connect a female connector to the other end, connect it to the SPDT; take the negative wire from the LED strip, solder a female connector to it, and connect it to the top terminal?
