Old 03-25-2010, 02:12 PM   #2
If the sedan happens to be the same as my LB, then this is the hole that you are dealing with in the front doors. You will need an adapter ring to make a 5.25 big enough.
Also, you will not find an adapter or spacer that will line up with stock mounting screw holes. Using the OEM as a template, you could fashion one out of MDF.
Rockford Fosgate or Alpine? dccurrent In Car Entertainment + Electronics (audio / video / alarm) 2 03-16-2009 11:16 PM
1000watt Custom built fosgate Sub box id3379 Items for Sale by private party 0 11-30-2008 04:29 PM
