Old 03-31-2010, 12:06 PM   #38
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by Duckywitbigfeetz View Post
never mind i got it planned it another way i will be making one turn and you are correct the correction factor only makes a .56 hz difference according to bass box. lol ... im making a wood / fiberglass box .. one last question now im looking at port velocity and i cant go any bigger area with port because length is not feasible is a 22 m/s speed ok. i see recomendations online to try and keep it below 18 any ideas.
I know if you use flared ports you can get away with a higher m/s value. For example, with the expensive precision ports you can get away with numbers closer to 30m/s. If you're using wood to make your port, just take a roundover router bit (the bigger the better) to the port openings. then sand it down nicely so it is smooth. It won't be as good as a precision port, but it will be a little better, and should be fine for you to go with that 22m/s port.
Make sure that you put in your actual wattage in that port velocity chart... the velocity will change alot from say 100watts to 400watts.
Hey Taln, what about using bigger amps AND level matching? :)
isn't that what I said???? oh gosh....
Help choosing Razo Pedal Cover wingdood Cosmetic Modifications (Exterior/Interior) 0 05-08-2009 11:39 PM
Help with choosing Amp kit myt In Car Entertainment + Electronics (audio / video / alarm) 7 01-20-2009 02:00 AM
Need to change my Sub, give me hand choosing the new one!! mledez In Car Entertainment + Electronics (audio / video / alarm) 10 01-11-2009 12:50 PM
Whats most important when choosing wheels? cdydjded Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-01-2007 10:33 AM
Hard time choosing color; dark colored cars absorb more heat?? fantabulousbaby New YARIS Purchase Forum 21 08-07-2006 07:53 PM
