#19 |
§†ęĄ¶‡Ћ-NCP96
#20 |
![]() Drives: 05 Scion xA Join Date: Mar 2010
i actually did the same thing to my scion xa, i guted out all the audio components including the radio as well as the back seats, and all the trunk components.. i took alot out of the car and i feel a world of difference in acceleration and handling... next up im actually gunna take the carpet and seast out, primer and rust proof the floor and paint it, then put the carpet back in until i get the money to buy aluminum and pan all the doors and create a rear pan to make the rear flush, all that tied in with 2 buckets and a roll bar/harness bar combo with 2 rear points so it is legal at the local drag strips
#21 |
we only need a cage here when we hit 9's.
#22 |
id3379
you still have your dash and airbags lol for some cali yaris we had to save a lot to get a car as safe as posable i am a uni student and would not call my yaris cheap in comparison to same older cars i could have got and i have to agree with 10DG22 on both why not have an other car and the each to there own part :) id3379 can you weigh the car to see how much its lost ?? and is there a big difference in speed ?? man you should of done a track day with all the gear in and then a day with it all out . sorry one other question you will be putting it all back to sell it when your don ?? |
#23 | ||
§†ęĄ¶‡Ћ-NCP96
#24 |
#25 |
Only Happy When it Rains
dude nice! I haven't gone that far, i don't have the right tools to remove some of the bolts and stuff. And i've been too lazy to look hard. external torx stuff seems to be a pain for me too find, lol. of course i am prolly just looking in the wrong spot.
next you should add some lightness, cf is fun!
Colin Chapman disciple |
#26 |
![]() Drives: 2007 HB Join Date: Feb 2010
I did all that, and then removed 2 of the lug nuts each wheel, the A/C, the dash, the windows (windshield is next), the fenders and hood. Pulled the e-steering box and drained 1/2 the fluid out of the cooling system and removed the heater core. As there were no problems, I took off the 3rd lug not each wheel, and tightened the remaining one to 120ft-lbs each. I then sawed off the other three lugs, as I wasn't using then, and turned the rotors down to 1/8" each side. I also sanded the pads down to the metal backing plates, shaved the tires, drilled the rotors and took off the drums and shoes outright. I used a hole saw to randomly cut 2" diamter holes out of the frame and flooring. I told my wife needed some money for balloons for our boy's birthday, but used the moeny to fill the tires with He.
Next I'm going to sand off all the paint and torch off the undercoat/soundproofing. I think my biggest savings will be when I remove the wheels/tires and take out the engine and transmission, that will save more weight than everything else I've done. I also give my self a coffee enema 1hr prior to driving, and am thinking of gastric bypass or an AKA amputation, just the left leg to start. And then I'm... |
#27 | |
^ I think this was meant to be funny? Or is this expressing some opinion?
Hard to tell. @AND189: Quote:
2. I had to save too. For over 30 years.
#28 |
gotta love stripping a car to "save weight" then leaving in the heavy stereo and speakers. i bet the stereo and speakers alone weigh more than a door panel ;)
#29 | |
#30 | |||
#31 |
If you want to save weight by stripping out all of what makes a Yaris a Yaris, then why don't you just sell it and buy a cheap old Echo. You save over 300lbs right off the bat and then you can strip out all the interior for another 100lbs. Plus you'll have a heap load of cash left over.
#32 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#33 |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
cut excess threads off all the bolts on the car. had a buddy take off almost 30 lbs in just threads...not even including what was turned into dust.
#34 |
Drives: Yaris 3dr Hatchback Join Date: Mar 2010
Have you weighed the car at any point during this? I have removed all you have expect the plastic (not worth the weight to make it that ugly), but I will say that removing all the seats/carpet/seatbelts/tire/jack, and some other little stuff made an enourmous difference.
I just wanted to weigh my car, and I am not sure of a good and cheap place. |
#35 | |
#36 |
civic, lancer, g5/cobalt, fit, versa, corolla, and too many others to think about....o, there is one more...the smart car lol
any way, you got a lot more to go, you still got: carpets non-essencial glass can be changed to lexan or poly carbon fiber or fiberglass door skins CF hatch headliner removed door panels with sheetmetal or fiber center console lightweight seats FG dash radio and speakers, amp if you got it can go excess wiring can be trimmed wires re-routed and trimmed (instead of a switch on left and right side windows you can move to the center) replace steel parts with aluminum trim up control arms and knuckles... there's tons of stuff you can still do to reduce weight. not saying any of it will be cheap or look good, but you still got a long way to go before you got no options left. |
| Official Weight Loss Support Group | DorytheYaris | Off-topic / Other Cars / Everything else Discussions | 118 | 02-22-2011 06:32 AM |
| Weight Reductions | scape | General Yaris / Vitz Discussion | 34 | 06-08-2009 02:31 PM |
| Weight Savings | 03Z33 | Performance Modifications | 30 | 01-31-2009 04:14 PM |
| Weight Savings - Removal, Reduction, Reminder.... | TRD_Yaris | Performance Modifications | 17 | 08-12-2006 02:07 PM |
