Old 04-09-2010, 08:51 AM   #12
markitect
Drives: Yaris
Originally Posted by yarrr View Post
The rest is pretty inaccurate as well. Springs don't compress with a linear rate(i.e. if one inch = 120 lbs then 5 inches != 600 lbs) All that work and measuring and you'd probably be better off with an educated guess.
The new springs won't be linear either, and yes, an educated guess is exactly what that gets you(you should see a few other things it's not accounting for).
Until you get someone to measure the unsprung weight I don't see how you'll get much better, and if anyone ever does that it will probably be a race-prepped one.
bobolinko:
The xD is basically the same as the yaris, but it's a heavier. So if you look at the spring rate page on the microimage forums you should get an idea of what is softer. But honestly I would get some 16" wheels, it will probably make more of a difference.
markitect is offline   Reply With Quote
ANCLA turbo kit warning! 1.5 Forced Induction Forum 11 02-26-2010 08:04 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 08:42 PM
Suspension Kit: Fully Adjustable or Lower Spring? JeremyG Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-23-2009 08:23 PM
Power Enterprise Super Charger Kit Round 2 $3100 Power Enterprise Evan Forced Induction Forum 312 03-26-2009 06:48 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
