Old 04-24-2010, 12:29 PM   #20
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by swidd View Post
Thanks talnk, turning on the hp filter with ~80 hz allowed me to push the volume an additional 3 clicks before distortion. The spx does not distort at all, without any filters, so this will let me to a greater degree match the rear spr to the front spx, for a much louder ride on road trips :)
Reason has to with the way the motor (magnet & voice coil) of the speaker is designed. When A speaker is played to play a note it moves, when it is told to play a lower note it has to move more in order to play at the same volume. The problem is that the further the voice coil moves away from the magnet, the less stable the cones movement becomes.... this means the cones has these micro-vibrations which cause sound... and the created from these little vibrations are not meant to be produced. That means it is distortion.
by setting that highpass @ 80hz, you have reduced the amount of lower frequencies that are sent to that speaker significantly. You get less midbass, but at the same time, you are reducing how much the cone has to move, which means you reduced a lot of distortion.... allowing you to hear the 80hz and up content at a higher level before reaching the same distortion level as before.
Cheers for going deaf quicker!
This limitation of speaker motors holds true for about 99.9% of midrange speakers, and 98% of subwoofers currently made. The JL W7 was one of the first very durable subs that didn't have this limitation because the designers actually tried to make a sub without distortion due to movement of the voice coil. There are a handful of companies now that have subs that use "linear motor" designs... Some seem to be better approaches than others, but all are better than the 100+ year old design that all other speakers use.
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
HELP! I changed a speaker while the car was running and now I hear nothing! dccurrent In Car Entertainment + Electronics (audio / video / alarm) 12 04-08-2009 06:44 PM
speaker holder speaker box KSIbucky In Car Entertainment + Electronics (audio / video / alarm) 10 11-18-2006 01:34 AM
Speaker Spacers - Pi**in me off!!! hasher22 Cosmetic Modifications (Exterior/Interior) 4 08-12-2006 11:28 PM
