Old 05-06-2010, 09:30 PM   #17
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by UTVitz View Post
But I'm a car nut and don't mind the expense. Everything I've read is that all oils are good no matter what you choose, but change it as it does get dirty every 3000-5000 miles. Some will say that's too early, but even the long term oil runners say change the filter-well I might as well do the oil too if I'm going to go to that much trouble I say.
Thats the thing with the yaris... you can remove the oil filter without having to drain your oil. You lose somewhere between a cup to a pint of oil, that is it. unscrew filter, a tiny stream pours out, put new filter in, put a cup or two of oil back in, and start her up. The longest part of the job is the time it takes to jack up the car.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Changing the oil lita_g DIY / Maintenance / Service 18 10-28-2008 01:59 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
