Old 05-15-2010, 05:03 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
07 Hatch 171K manual
actually my water pump looked perfect, but I already have a new one coming. I'll
put it in... my problem is definitely the cam timing gear. If I could I would get a mechanic to
install a regular non geared cam sprocket and do away with the entire VVTI system.
But I probably couldnt find the right fit, unless someone knows how to do this???
by the way... my AC compressor pulley bearing is bad... I dont need AC so am going to install a smaller belt and bypass the AC. Anyone know the exact size of a smaller belt for that???
otherwise I will measure with a string......
yaris9876 is offline   Reply With Quote
Old 05-15-2010, 09:25 PM   #2
No need to measure - The Toyota part number is: 90916-02499 for the shorter one. You can also get a non-OEM one by having your auto parts store look up the one for a Yaris without AC.
Old 05-15-2010, 11:18 PM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
A 1/2" ratchet with a 20" extension got mine off immediately. Didn't even really need any additional leverage. I also put a crowbar in the spokes of the pulley to hold it in place.
You could "rent" these by going to home depot / sears hardware / lowes, buying them, using them, then returning. I didn't see much use for a 1/2" ratchet, so I was quite thrilled to have gotten the install done without paying any additional money.
Old 05-16-2010, 01:55 PM   #4
yaris9876
thanks for the belt number. Thats good info.
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 05:54 PM
NST Crank Pulley Reliability? WeeYari Performance Modifications 59 02-10-2010 01:20 PM
New NST Pulleys for the TS NonStopTuning Yaris TS Talk 70 11-03-2009 04:19 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
ZPI pulley installed! PetersRedYaris DIY / Maintenance / Service 5 04-10-2007 07:31 PM
