Old 05-14-2009, 12:12 PM   #19
ChinoCharles
Drives: LB
If you build it, they will come...
Old 05-14-2009, 12:22 PM   #20
severous01
i use moly lube...same thing u put on ur piston rings but it's in a powder form. it's awesome...and it's dry
if you can't or dont want to pay 15 bux for moly lube get graphite for about a buck in any hardware section or store or evey parts place.
Old 05-14-2009, 12:24 PM   #21
OK. Someone without the power package, pull the rear hatch cover and see if there is a two pin connector sitting there with a pink and grey wire.
Old 05-14-2009, 12:29 PM   #22
ChinoCharles
Drives: LB
I can do that this weekend.
Old 05-14-2009, 12:32 PM   #23
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I would avoid the use of WD-40 in just about any application as it attracts dust. You're better off with a "dry" lubricant such as a graphite-based or teflon-based one.
WD40 drys out and becomes gummy. When that happens, try LPS 1 to dissolve the WD40, then go to a dry lubricant.
Old 05-14-2009, 01:57 PM   #24
toyo
Drives: toyota
don't have that problem. but you can fix it buy sharpening a pencil and using the powder left. get some on the key and it works like a miracle.
1st gen FTW
toyo is offline   Reply With Quote
Old 05-14-2009, 07:27 PM   #25
bladesmith6
Drives: 2007 yaris HB
that was my first thought, a switch in the console and a single actuator, but then if i'm out somewhere I have to open the car to put packages in the hatch. Full set of locks might be a better idea...
bladesmith6 is offline   Reply With Quote
Old 05-16-2010, 09:24 AM   #26
SamH
Drives: Bayou Blue Yaris Hatchback
They make a graphite lock lubricant you can get at any hardware store in the US
SamH is offline   Reply With Quote
Power upgrade (pictures). W.A.S.P DIY / Maintenance / Service 91 11-15-2017 11:32 PM
Yaris Hatch Purchase warlock New YARIS Purchase Forum 7 09-03-2007 12:59 AM
Hatch on Liftback sambo42xa General Yaris / Vitz Discussion 0 06-07-2007 07:45 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 06:55 PM
Power hatch lock? paultyler_82 DIY / Maintenance / Service 5 09-08-2006 02:15 AM
