Old 05-28-2010, 10:05 PM   #235
sk8manmike
sk8manmike's Avatar
Drives: 2007 Yaris 4d Sedan
HOLY CRAP......
Ok let me tell you about the scary thing that happened to me right when i was about to get done with this mod.
I finished attaching my switch to the ECM and was now going to do the wire jump in the fuse box on my 07 MT Yaris..........
I put the first wire inside next to the white cable on the right and as I was putting the cable into the slot with the blue cable --- the car freaking lunged forward about 6 inches. Needless to say it scared the s**t out of me. I had the car on halfway (engine off - lights on), so i thought maybe it just did that because i had it kinda on. I turned it all the way off and tried again - same thing happened.
I attached pictures below to show you what i did and can take more if need be.
So whats going on guys? You think theres something wrong with my switch - like the buttons are always on or something?
When it lunges forward and always sounds like it wants to start - i think it stops because i pull the wire out when it lunges at me.
Any advice?
ECM CONNECTOR
CURCUIT BOARD
FUSE BOX - FOR CC JUMP, I put other wire next to the blue one and it lunges at me.
sk8manmike is offline   Reply With Quote
Old 05-28-2010, 10:25 PM   #236
Even if the switches are NC instead of NO, it shouldn't try to start. I see you are using a piece of bare wire. Are you sure it is only making contact with the blue and white wires?
By the way, the violet wire between the blue and white is the output to the starter, so making contact with it would indeed crank the starter.
Also, your Sedan is MT, not AT?
Old 05-28-2010, 10:35 PM   #237
sk8manmike
sk8manmike's Avatar
MT - i'm pretty sure i've only been touching the blue wire - i made the wire have a lot of bare wire so that i can check the voltage easier
Old 05-28-2010, 10:54 PM   #238
Everything looks correct. I would make your connections with the ignition off (and perhaps the battery disconnected as well). Then, carefully connect the battery / turn the ignition on.
Old 05-28-2010, 11:22 PM   #239
sk8manmike
sk8manmike's Avatar
I can't seem to produce any Volts between the connection anymore - it took me awhile to get the previous ones too. I'm pretty sure that the connection is whats keeping my CC from working.
Any idea who sells T Splice or something similiar? I'd hate to have to buy it from Amazon and wait another week.
Old 05-28-2010, 11:28 PM   #240
Radio shack and most auto parts stores sell them.
Also, to make sure your switches are correct; If you measure the voltage between the two terminals of the first switch, with the ignition on, you should see 12 volts. If you see zero, then your switches are normally closed, instead of normally open.
Old 05-28-2010, 11:45 PM   #241
sk8manmike
sk8manmike's Avatar
I'm not getting any voltage on the first switch.
This the switch for all four spots: http://www.radioshack.com/product/in...ductId=2062543
One of the reviews states that besides being crappy switches, they have a habit of going to a closed states when worn.
Old 05-29-2010, 12:12 AM   #242
sk8manmike
sk8manmike's Avatar
I'm using 22 Gauge Wire - is that what gauge T Splice I should get? I'm not sure what gauge wire runs to the fuse box.
Old 05-29-2010, 11:18 AM   #243
It's somewhere between 18 and 20 gauge I believe. The tap splices are usually good for a range, so if you can get 22 to 18 gauge ones you'll be fine.
For the no voltage on the switch, measure the red wire to ground (with the ignition on). If that is still zero, then disconnect it from the switch and measure the red wire separately to ground. If it is still zero, than your ECM pin is not properly seated.
Old 05-29-2010, 01:39 PM   #244
sk8manmike
sk8manmike's Avatar
Nice - My Terminal in the ECM wasn't completely seated - looking back at my first pic you can clearly tell that its only partly in. I have voltage now going to my switch and i'm going to do the jump and pick up some T Splice afterwards.
Old 05-29-2010, 01:54 PM   #245
sk8manmike
sk8manmike's Avatar
Yay! It works......Thank you for constantly moderating this thread CTScott - it's good to know that when you attempt mods on this site your not doing it alone.
Old 06-07-2010, 11:22 PM   #246
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
Hello,
I just put in an OEM Cruise stalk to replace my little 2 button diy one and I made a discovery regarding the $30 toyota cruise wire. The pins that go into the horn connector as well as connector D3 seem to be the same as those for an R/C servo, example:
It's a little finicky to get them into the white plugs, especially D3 which I discovered has a lock you have to loosen with a tiny flat thing. I don't know if these will work with pin 40. As a bonus the servo connector also fits into the OEM cruise stalk, though its pin spacing is a little wider so it bends the contacts a little, and there's no locking mechanism so I guess it could vibrate loose, though mine feels pretty firmly seated.
Happy DIYing!
Yarisduder is offline   Reply With Quote
Old 07-11-2010, 06:54 PM   #247
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Sorry to revive this thread here folks, but on a CAD Yaris auto LB (2007), I need the OE Toyota stalk, and the pin-40?
I read the the instructions of Sparks, and no mention is made requiring the pin-40 mod... Therefore, I am a bit lost.
Old 07-11-2010, 10:00 PM   #248
On an 07 you will need to add the wiring from the stalk connector to the ECM pin 40:
http://www.yarisworld.com/forums/sho...ght=faq+cruise
Old 07-12-2010, 02:23 PM   #249
firemachine69
Thanks Scott.
Looked at the Sparks list, apparently it wouldn't be required. Considering my shipping is the cost of the wire, I'd be pretty pissed off if I had to do two separate orders because of their innacurate instructions!
Old 07-13-2010, 03:15 PM   #250
darkMINI
Drives: 08 hatch
Using the toyota stalk I got from salvage yard on the column, in an '08 MT, is the wiring already in the column for the switch to connect to or would I have to mount this switch stalk elsewhere?
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 07-13-2010, 04:03 PM   #251
The wiring from the inside of the steering wheel to the base of the steering column is there, so you can mount the stalk where it belongs. If you didn't get the wire to connect the stalk to the clockspring (AKA spiral cable), then you will need it. You will also need to add the wiring from the ECM to the steering column.
Old 07-13-2010, 07:23 PM   #252
darkMINI
Drives: 08 hatch
Ok, thanks CTScott, is there a picture somewhere of this "spiral cable" you speak of? My stalk has a red and white wire coming out of it that end at a plastic connector that also has a short white wire with a female spade connector, but its not spiralled.
When I raped the poor Corolla of its cruise stalk I didn't see a spiral cable in the steering wheel.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
