Old 05-31-2010, 01:21 PM   #19
racerfreak, it's simple. You can't swap in ANY ECU to the Yaris and have it run all the safety features and sub systems correctly. And you can't correct all of that with management. My understanding is you can't even swap in a Japanese Yaris ECU.
Old 05-31-2010, 03:30 PM   #20
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
Well I guess having patience is all we can do now. I guess one step at a time and maybe one day someone will crack this ecu.
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 05-31-2010, 03:54 PM   #21
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Originally Posted by Nexus1155 View Post
get someone to wire it for another $100, and then tune for like $300..
i wish i have gotten those rates!
Originally Posted by RacerFreakXXX View Post
There is a blitz supercharger, that still needs to be tuned to work properly
WTF? Tuned to get it's max power, since it has a conservative tune; but tuned to work properly? WTF?
Old 05-31-2010, 04:00 PM   #22
cdydjded
Drives: Yaris LB Turbo
Rates like that only exist in Wonderland.....
Old 05-31-2010, 04:03 PM   #23
cdydjded
Hey Garm did you take a look @ the Dezod ECU? It basically makes the factory ECU programable. CAN BUS and all..
Old 05-31-2010, 04:03 PM   #24
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I must be giving people killer deals then. I should double my prices lol I try to keep low for economy and to help people out., but anyone who would charge you over that to splice in like 20 or so wires, and anything more than $150 per hr tuning is too much imho
Old 05-31-2010, 04:21 PM   #25
cdydjded
Cant compare a guy working out of his garage with no overhead to a legitimate business with a payroll & rent to pay. Id luv to see a standalone system that has 20 wires to connect. You get what you pay for.....
Old 05-31-2010, 04:50 PM   #26
Nexus1155
Drives: Audi
This is before we re-did the shop, its not much but its my home away from home. I really wish it was out of my home garage so I wouldn't be getting raped with rent :-/
20 wires was an understatement in most cases i do admit, but i was talking about a piggyback, just installing it in a kick panel, wiring the harness, and pulling them all through the firewall into the engine bay and wiring it up there.
Old 05-31-2010, 08:20 PM   #27
^ do you have a dyno?
Nexus, your rates are unusually low - I think that's great, no criticism there, but I also think you can't simply generalize to all markets.
The only decent dyno tuners in LA charge $250 per hour and up, and there are only three of them that I would trust my car with.
Old 05-31-2010, 08:35 PM   #28
Nexus1155
Drives: Audi
No, sadly not, we were thinking about renting out another unit next door or behind us and chopping down the wall. Its 1500sq ft right now and we are packed to the brim kind of with all the equipment and cars we have in there.
We are on bad terms with the landlord already for overcrowding the parking area. 3 S4's outfront, 6 out back and like 3 BMWs and 2 astro vans and were really only suppose to have 5 spaces all together.
We can't really charge inflated rates here, but we do to some people who are willing to pay. A coworker did a job the other day for control arms and half shafts and banked in $850+ which is pretty good.
Old 05-31-2010, 09:37 PM   #29
cdydjded
Well I stand corrected in assuming you work out of your garage at home. And Im glad that you realized your understatement. But my last point on this discussion is that the Dezod piece is not a piggyback. Its a unit that converts the factory ECU to a fully programable ECU. Its plug & play, it allows all factory functions to work, power steering, Can Bus, OBD2 port, A/C ect ect. Its not for everyone. The AEM FIC & eManage will sufice for 95% of the people here. This unit is for the person who want full control of the factory ECU or someone who has a built motor & is turbocharge or S/C & want to make real power.
Old 06-01-2010, 10:37 AM   #30
It's for the tC, not the Yaris. Like you said, it's the future for our car.
Old 06-01-2010, 11:20 AM   #31
cdydjded
This unit is made by APR. It was originally made for the 4.0 Toyota trucks with S/C. Dezod & APR join together & with some internal modifications they got it to work on the TC. Dezod also got it to work on the xB2. The box itself is kind of universal but requires a jumper harness to connect to our ECU. Right now we are at the point of testing it on the Yaris.
Old 06-01-2010, 11:35 AM   #32
to be continued then, sounds good!
Old 06-01-2010, 11:46 AM   #33
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by cdydjded View Post
Actually, I think this is the future: http://diyefi.org/index.htm
But we need something more plug-and-play...
Old 06-01-2010, 11:53 AM   #34
cdydjded
IMO this is more than most people can handle. I dont think people here are going to have the knowledge to put together an ECU to run there car. Its an option but I think it down low on the totem pole.
The unit Im working on is as PnP as it gets. Not one solder, crimp, tap is necessary.
Old 06-01-2010, 01:47 PM   #35
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
The problem is that standalones are becoming harder to PnP with newer ECUs. My Miata is simple, and for less than $500 I can buy a kit to assemble a fully programmable replacement for the stock ECU (Megasquirt DIYPNP). That's because the ECU runs the engine, and that's about it. The Yaris runs all sorts of shit through the ECU that's hard to replicate. Air bags, emissions testing, A/C, cruise control, immobilizer, etc.
You could build a unit that would control the stock timing and fuel without too much difficulty, but half the car still wouldn't work. That's why reflashes and interceptors are becoming more and more popular; it's hard to run anything else on a modern car.
bearda is offline   Reply With Quote
Old 06-01-2010, 02:07 PM   #36
cdydjded
I concour with bearda. As for building something, IMO it better to just buy a AEM FIC or eManage.
Thinking of Swapping your Gauge Cluster? Sabretooth Cosmetic Modifications (Exterior/Interior) 3 08-17-2009 05:18 PM
Swapping Out Gauge Pack schreck Fuel Economy Forum 80 07-16-2009 12:53 PM
Help with ideas of swapping system out of my other car to my yaris YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 01-22-2009 01:23 AM
Swapping Rear Seats - 3 door youcbs General Yaris / Vitz Discussion 1 06-21-2007 09:07 PM
Swapping seats question Presto General Yaris / Vitz Discussion 6 05-01-2007 03:25 PM
