#13 | |
There is not a set number "style". You wont be using the ridiculous Regional numbers, example 842. The windshield banner is free, and they should be available at the event. You have to buy the SCCA wire wheel logo decal for the front, and the Div decals for the sides, also available at the event. 3.7 VEHICLE IDENTIFICATION A. All vehicles must display numbers and class letters on both sides, which must be readable by Timing & Scoring, Course, and Grid workers at all times. B. Only one set of numbers and class letters may be visible while the vehicle is running. C. Class shall be represented by the upper-case abbreviated form rather than be spelled out. Ladies’ classes shall be indicated by the letter “L” following the class letters. (Example: “BSPL” instead of “B Street Prepared Ladies”). D. Numbers and class letters should be positioned next to each other. All letters and numbers must be on body panels, not on windows. All numbers and class letters must use the same typeface and the 2010 SCCA NATIONAL SOLO RULES — 39 same color, and this color must provide adequate contrast to the background color (see Appendix F for examples). E. Numbers must be a minimum of 8” high with a 1.25” stroke. Class letters must be a minimum of 4” high with a 0.75” stroke. In all cases, the height of the class letters must be between 25% and 75% of the height of the numbers. Stroke width must be at least 10% of the height (see Appendix F.) F. The “1” on two-driver cars and the “L” on Ladies class cars are subject to all of the above requirements with regard to placement, color, size, and stroke. H. For National Championship, National Tour, and Divisional competition, current offi cial SCCA required decals must be displayed on each side of the vehicle in a prominent location. For National Championship, National Tour, and Divisional events, one offi cial SCCA-approved National sponsor identifi cation logo must be displayed in an upright position, in a prominent location on each side of the vehicle. Further information is contained in Appendix F.
