![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
I couldn't get this to work. I tried a 2.2k, 5.6k, and 10 ohm resistor and no dice.
Anyone have any advice? The dealership refuses to disable it for me because apparently it's a federal law to have seat belt sensors now
The seatbelt latch has an active circuit, so you can't just bypass it with a resistor. Your best two options are to 1-Find someone with a TechStream tool and have them disable it for you or 2-remove the piezo chime from the cluster.
#3 | |
![]() Drives: 2008 Toyota Yaris Join Date: Feb 2023
I have no advice-- but I am in the same boat. It did not work for me. All splicing in a 2.2k ohm resistor did was make the airbag light come on too. Did you figure out a solution? |
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Back Seat Removal... | Idjiit | DIY / Maintenance / Service | 87 | 02-08-2015 12:07 PM |
| Seat belt reminder warning Beep | Jord | DIY / Maintenance / Service | 28 | 04-09-2009 08:37 AM |
