Old 06-11-2010, 04:43 AM   #20
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
Originally Posted by aucorium View Post
haha , i like the no speed limit rule , i have only been to 200 kph twice in my car , as here there is alot of speed traps. but i will check the oil again to see my level.
ok great , thank you , let me know what you find out , would be cool if the celica aftermarket discs could work on the TS.
hi buddy
if the oil is going to give problems then change it with a high performance oil, also u need to keep a eye on brake fuild, if the disc are getting warpped that means the temp is high, brake fuild boils at 200 and something degrees, find out what dot is in your car and change to a higher one, that should help also
www.justbabynappies.co.za
nazier is offline   Reply With Quote
OEM Yaris brake pad kit PICS auxmike DIY / Maintenance / Service 17 11-24-2009 11:42 AM
