Old 06-12-2010, 11:47 AM   #7
RedHatch08
Canadetroiter
RedHatch08's Avatar
Drives: 2008 3DR 5M
Originally Posted by bzinn 1 View Post
Well a couple of questions first.......
How much money do you wnat to spend.......
What type of music will get played most often.....
Sealed or ported box........
SPL or SQ setup or a bit of both.....yes it can be done...
Do you plan on sound deadening the car.......
How many watts.......
Can you tune an amp......
Are you gonna run amped comps with the sub or just deck powered speakers.....
That is a good starting point to figure out what direction to go in.....
Since the Yaris is such a small car, you should also ask yourself how much space you want to give up, and where you want to position the sub.
I'm going through this process right now myself, trying to figure out what stereo gear to put in.
I'm personally a fan of sealed boxes when it comes to in-car use. Sealed boxes save space over ported, and with the effect of cabin gain, can get plenty loud.
This is especially true if you're careful with your selection of components. With subs, try and look for something with a high sensitivity/efficiency rating. This can be kind of hard because lots of companies flat out lie about this spec, but keep it in mind. Speakers with higher sensitivity play louder given the same amount of amplifier power. This will help you get the most output out of whatever amp you use.
K&N Air Filter . Rear Debadge
RedHatch08 is offline   Reply With Quote
My new subwoofer setup! Nexus1155 In Car Entertainment + Electronics (audio / video / alarm) 14 12-19-2009 08:11 AM
Yaris Subwoofer shtou In Car Entertainment + Electronics (audio / video / alarm) 2 12-18-2009 12:04 PM
Subwoofer Help - HELP ME PLEASE *MAD DOG* Off-topic / Other Cars / Everything else Discussions 14 10-27-2009 11:25 AM
whaty kind of keys does a new 2009 yaris yrs come with PAULY Australia 8 09-12-2009 03:55 AM
Kenwood KSC-SW1 Powered Subwoofer seriousfun In Car Entertainment + Electronics (audio / video / alarm) 11 04-02-2007 02:44 PM
