Old 06-17-2010, 02:09 PM   #7
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Somebody needs to look in a Toyota parts catalog to see what's different. They might share common rods and have pistons with different compression heights. Cams might be the same or not. Note that the 1NZ-FXE engine in Priuses is basically the same as the 1NZ-FE with an even higher mechanical compression ratio around 13:1, also.
350HP on 2ZZ-GE? forpinks Performance Modifications 42 04-02-2007 11:01 AM
