#19 |
![]() ![]() Drives: 2009 yaris 4dr hb Join Date: May 2010
if you get it at the dealer its going to costs you close to a thousand... but i suggest to go to a detailer shop and they usually do a pretty good job for cheap. Also if you buy the warranty at the dealer they will only 3m the hood and the side mirrors which sux... well thats what they do here anyway...
#20 | |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
For the dents is better let the pros take care of it, I used some kits and is hard to get a nice result. http://www.langka.com/index.php |
#21 |
![]() ![]() ![]() Drives: 2009 Toyota Yaris Join Date: Jan 2009
Hmmmm I just checked out that Lanka site ( ^ ) and that seems like its something that I can do! do you think that this method would work on the chips that are on the front lip/edge of the hood where alot of the chips are?
Thank you for your help :-D |
#22 |
It should anywhere where paint is chipped or missing; I have been able to fix chips and long deep scratches with this method, you just need some patience to do the job, I think this is a lot better thank re-painting.
#23 |
its not that big white spot in the middle is it?
#24 |
^hahaha oh god no! That was a reflection of the flash...
@ Lucas 13 .... I just ordered the Lanka set thing ...I'll keep you guys updated on how it works.... Thanks |
#25 | |
You will be amazed how this works is a cheap and better solution than painting the whole thing, I used it on my last 3 cars and the yaris and I always get nice results.Let me know any questions you may have! |
#26 | |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
#27 |
Sounds like you need to wash and wax more often...
