Old 09-15-2012, 12:55 PM   #1
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
just awesome!!! what engine management do you normally uses ? piggy back ?
Interior:ALL red, black roof
Old 09-17-2012, 12:28 PM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
If anyone is interested in the manifold e mail Andrew@ptuning.com
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 09-18-2012, 08:47 PM   #3
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I called about the manifold he said it would take a month to make one. If U had it in stock I would have bought one. You should keep a couple on the shelf. Im still liking it, mabe for spring. Dont want to swap it out in the cold.
pimp my yaris is offline   Reply With Quote
Old 09-23-2012, 11:01 PM   #4
pimp my yaris
C'est la vie
I recently had a huge loss in power while tuning at 19 psi of boost. I thought it was a clogged converter or muffler. Possibly a boost leak or BOV not closing. That was all wrong, it turns out I had a mass air flow sensor trouble code. I could not see it because my CEL is on all the time because my 02s sensors are disconnected. I cleared the code and the problem is fixed. Back to full power. I may need to adjust my MAF clamp voltage.
Old 09-24-2012, 07:01 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Probably an out of range code and it went to default values.
Old 09-29-2012, 02:58 AM   #6
packetrace
packetrace's Avatar
The ptuning maniold on their website does not look equal lenght ?
Old 09-29-2012, 08:11 PM   #7
pimp my yaris
C'est la vie
I think its about as close as you can get woth the space under the hood. I have seen one other but it required relocating the battery. And was over 2000$. I like the turbo above the valve cover. Looks cool and will make the exhaust much straighter and easier to fabricate.
Old 09-29-2012, 08:42 PM   #8
packetrace
packetrace's Avatar
welll Parmas has build an equal lenght one...he is selling it...i have asked if he wants to sell it alone with down pipe and not with whole piping....
TBR makes one which might be the one your talking about...:)
Old 09-29-2012, 11:34 PM   #9
The one Parmas had came with the motor from Canada -- he didn't build it, as I recall.
Old 09-30-2012, 09:17 AM   #10
Radou
Radou's Avatar
Drives: yaris 09 ncp91
i think is an engine from turbinetech here !
Radou is offline   Reply With Quote
Old 09-30-2012, 11:37 AM   #11
packetrace
packetrace's Avatar
Yes it is :) they want 1000$ for an equal lenght haha
Old 09-30-2012, 11:40 AM   #12
packetrace
packetrace's Avatar
Might pick one from ptuning or try to copy it of parmas dont want to sell his equal lenght alone
Old 11-26-2012, 09:55 AM   #13
pimp my yaris
C'est la vie
Just posting an update. I have sorted my ignition issues by adjusting my timing map. My car has been running very strong at 17psi. Making more power then ever before. I continue to tweek and fiddle with the FIC. Sometimes adjustments work and sometimes they dont. I can say it is getting hard to tune on the street. Sometimes I wish I had a dyno. Trying to find a road to wind out forth gear is a little risky with traffic and the police.
Traction is a real problem. With cold weather their is none until third gear. Even third gear is starting to break loose somtimes. And I have major torque steer. Mabe a limited slip would help.
My light piston slap has not caused any issues with reliability. I just finished a trip to Tennessee with my bike on the trailer behind my car. It is pretty loud when cold but its taking some hard driving.
I want to get a dyno run in the next few months and see what she puts out? I also want to pick up a welder and build a quality exhaust. Also next summer I would like to get a new turbo manafold and slightly larger turbo with a external wastegate.
Old 11-26-2012, 12:31 PM   #14
^ Way to go!
LSD will help a LOT with your torque steer, I have very little of that on my car. Tires may be helping, I don't know, I run Toyo R888's, very sticky tires.
Old 11-26-2012, 01:07 PM   #15
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Glad to hear all is going well for the most part. I am very glad that I went with an external WG...just makes life a lot easier as well as being more reliable in winter conditions. My daughter actually had a friend over from New Brunswick during the Turkey Day weekend and he has a boosted Golf that had an internal WG that experienced the same issue I did with the actuator sleeve arm getting gummed 2 winters ago. He got lucky though because his stuck closed rather than open so no damage, just shitty performance.
Old 11-26-2012, 01:34 PM   #16
kou
Drives: 08 lb
I think you got that backwards, if stuck closed it would build up to much boost stuck open it would not build any boost.
Old 04-20-2013, 11:21 AM   #17
fnkngrv
fnkngrv's Avatar
Oh yeah.... haha
Old 11-26-2012, 02:53 PM   #18
^ Correct.
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
