Old 07-19-2010, 03:37 PM   #1
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Ya I may try a mbc later. Its already a 8psi actuator. Thats gonna be pushing it for a stock motor. I think I will use some header wrap for the down pipe. And mabe another piece of sheet metal between the turbo and fire wall. The only thing close to the turbo is the brake line that runs to the passenger side front wheel.
pimp my yaris is offline   Reply With Quote
Old 08-08-2010, 10:18 AM   #2
pimp my yaris
C'est la vie
Update: I ordered a front mount intercooler and 2.25" piping kit and also an additional piping kit as well and a adjustable bov that can be piped to recirculate. And a oil feed line with t fitting to tap into pressure sensor. This size should work well. My turbo,T/B and air box should fit 2.25" silicone connectors. I am going to try to use the stock air box and mass air. It may cause problems with fitting intercooler piping later though. I also have a question guys> Where are you tapping into to get your coolant for the water lines on the turbo?? I am thinking heater core lines would be the most obvious choice. But Im not positive.
If anyone is intrested, so far I spent 876.99$ including shipping
File Type: jpg !Bth)C0w!2k~$(KGrHqMOKkUEvO9Tt5yuBL8(,ugt8g~~_12.jpg (16.2 KB, 356 views)
Old 08-08-2010, 01:00 PM   #3
cdydjded
Drives: Yaris LB Turbo
2.25" is correct on the I/C pipe size. You will not be able to use the stock air box, it wont be able to be pressurized. IMO you do not have to flow coolant through the turbo.
cdydjded is offline   Reply With Quote
Old 08-09-2010, 04:31 PM   #4
pimp my yaris
C'est la vie
I am planing on putting the mass air before the turbo. That way I can hopefully use stock air box and cut down on costs.
Old 08-08-2010, 11:06 AM   #5
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
wow you dont waist much time do you. looks nice its coming together
Yoda is offline   Reply With Quote
Old 08-08-2010, 12:12 PM   #6
heater core lines will work fine. I have to check mine, I thing we used one in a different place that was available off the block.
Old 08-08-2010, 01:21 PM   #7
If the turbo has water line inlets/outlets, use them! -- I love not needing a turbo timer or to have to sit there for 30 seconds idling before I jump out of the car.
So there you go, two opinions to consider.
Old 08-08-2010, 01:34 PM   #8
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Malarky!, the shaft of the turbo is still spinning like 1,000,000 mph like a speeding bullet you want to keep it cooled down. If the turbo has useable ports for water cooling, use them as alot of the heat is transfered into the coolant and pulls it away.
Old 08-08-2010, 04:41 PM   #9
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Race you to be the first to finish their build.
Focus_Sh1ft is offline   Reply With Quote
Old 08-09-2010, 04:14 PM   #10
pimp my yaris
C'est la vie
Its on! I hope to be runing sometime in october.
Old 08-08-2010, 07:30 PM   #11
^ I win.
Old 08-09-2010, 12:55 PM   #12
cdydjded
pimp: I would suggest to use the coolant lines that run through the throttle body if you are going to run coolant lines through the turbo
Old 08-09-2010, 04:33 PM   #13
pimp my yaris
C'est la vie
Thanks for the idea. I think that will be much easier then the heater lines. I dont want to restrict those lines, it gets to dam cold here in winter!
Old 08-09-2010, 01:37 PM   #14
Yoda
Yoda's Avatar
^that might work actually
Old 08-09-2010, 07:21 PM   #15
pimp my yaris
C'est la vie
Well I just picked up some used 1ZZ injectors that were for sale on E-bay. If anyone was thinking about picking them up, TO LATE I got um! New total 939.49
Old 08-11-2010, 07:08 AM   #16
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Bad for you I have a set of these for sale for much less
The Aem is a good choice but an expensive one although you would be happy with it.
I think that intercooler is good for now but if you are thinking of more boost later on you will regret you didn't bought one better.
Don't rush out and do think before you act. Getting the right parts now is an investment for the future and you would not regret the time spent for research!
Good luck!
Old 08-11-2010, 09:00 AM   #17
pimp my yaris
C'est la vie
Good luck!
I bought used injectors off ebay for 62.00$ with shipping. 939$ is total for eveything I spent so far including Turbo, manafold, intercooler, two piping kits, oil&coolant lines. Still need to buy AEM fic, AEM widebend, stai less pipe for downpipe and exhaust output flange for gt25 turbo. O ya I need more Flow$. Any one got donations
Old 08-11-2010, 09:58 AM   #18
Nexus1155
Drives: Audi
The AEM UEGO is a hunk of crap but im sure it will integrate well with the AEM FIC which is always a plus. Parmas, I doubt he will build his car to handle extreme boost, that FMIC will do him good for any boost he needs to push on that turbo.
Oversizing the intercooler and piping for it, and for exhaust in the car is a common mistake alot of people make.
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
