CERTIFIED ASE/SUBARU TECH
Hey guys, I had the privilage of tearing down a 1NZ-FE....and what i found was not pretty.The customer was NOT changing his oil regularly, and when he did...it was done at wal-mart or those fast lube places.The pcv valve clogged up,resulting in a severe amount of carbon in the cylinders.After removing the oil pan, I found this blob of yellowish sludge all arount the oil pick-up.Just thought you guys should know...i have pics, if anyone is interested.
Pics please...
![]() ![]() Drives: 07 Yaris Sedan Join Date: Jan 2009
Please post pics... now I want to replace my PCV valve each time I change my own oil and filter.
#4 | |
2007tRD , is removing the valve cover the only way to get access to tightening the bolts for the head gasket ? Do other components besides the valve cover need to be removed to get to them ( camshaft , etc. ) ? Are there any bolts oustside of the block to tighten or are they all internal ? We have oil leaking from the head gasket for both our YARIS . Hoping head gasket bolts can be checked for proper torque from factory and applied if needed to stop the leak for the YARII . Rather have the valve cover removed than both the heads . THANKS .
pics...appropriated
Look at your own risk....and yes, the valve cover,water pump,front cover,timming chain and cams need to be removed to replace a head gasket.This engine has 102k miles.There is no need to replace the pcv valve at every oil change,a 5-gas can tell you if your engine is running out of spec.
Looks like contamination in the oil pan. Water or coolant possibly, but it is possible it was a problem with the oil itself.
Wow , that's funky lookin' . Wonder what brand of oil was used and how often it was changed ? That's why we prefer new to used when buying . Be it CERTIFIED or not . Even though we have a 2010 and 2008 that leak oil from the head gasket . The 2008 is worse at 23,000+ miles . The 2010 seems to have slowed done . Great pictures and thanks .
2007tRD , can you tighten the head bolts to stop the gasket leak by only removing the valve cover ?
diaper change in a yaris
Drives: 2009 multimode hatchback 5dr Join Date: Dec 2009
does the usage of synthetic oil also produce sludge buildup? i know that the corolla's made in 2003-2006 had a very severe sludge problem here in Israel..
"there is no secret to the balance..you just have to feel the waves.." Heretics of dune. |
Looks like cams will most likely be in the way.
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
if the head gasket is leaking already, tightening wont fix it.
you need to replace it. and i'd suggest fle-pro gaskets, or mr gasket gaskets. i know everyone says "oem is better...bla bla bla" but fel pro does their homework. they've remedied leaks for GM, ford, toyota, chrysler, jeep, and dodge that i know of. they have awesome gaskets and i've never had a problem with any of their gaskets leaking. any way, enough of that before you guys think i sell their stuff lol. any way, you'll need new head bolts as well. you cant' reuse them, they're torque-to-yield bolts...never reuse. |
#13 | |
Compare OEM GM V8-V6 plastic/silicone intake gasket vs the Fel-Pro steel/dense rubber version...funny how Fel-Pro fixes the known design flaws but OEM won't; guess it keeps the dealership busy with those steady $550.00-$900.00 intake jobs. |
the area in red is where it leaks under the gasket for the '08 and the '10 . Thanks to all for your input .
#16 | |
You'd think that there must be other YARIS , 1st generation XBs' , or XAs' with the same leak . Why just ours . I really believe that starting the the use of synthetic oil at 1,200 miles for both is the cause . I've looked at 2 XBs ( 1st gen. ) and 3 YARIS with higher mileage for same leak and were bone dry . The '08 with 23,000+ miles leaks more than the 2010 with 8,000+ miles . Figure due to the longer run of synthetic for the '08 ( up to 21,000+ miles ) than the '10 ( syn until 7,000+ miles ) . Now using conventional motor oil for over 1,000 miles for the 2 . Talk about sh*t for luck .
![]() ![]() ![]() Drives: toyota Join Date: Feb 2009
my god, that car owner shouldn't be allowed to own cars lol
1st gen FTW
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
