Roadrunner Jr.
Okay...ummm...yeah. There is no "Bass" or "Trebble" toggles. It's all in the EQ and Crossover section. You'll have more than you ever need.
with the function button (the right one) to get to your EQ and crossover sections what you'll need to do is: While the unit is on, go ahead and rotate the function button either left or right. This will job the display into "Audio", "Display", or ""Function". Note I haven't even turned mine on in two weeks because I'm waiting for the last 2.9 to get here... Obviously, choose "Audio" In the main audio menu, you can turn the function button left or right throughout the whole process EXCEPT in some sub menus. At this point we're just floating around in the upper menu. What you'll do is to jog the function button until you reach the crossover slopes display. At that point you'll press the function button in. That should give you the ability to float around the 4 way crossover. Now, you SHOULD play with this. You'll be able to range the slopes in regards to frequency range and you'll be able to independantly adjust both left and right on said slopes. Now this adjustment takes another press of the function button BUT I would say to leave it alone and just do broad changes until you're used to the deck. You also have the ability to mute any section of the crossover. This is particularly useful when you're tuning... I KNOW there's more. I'm just wasted from a 13 hour work day yesterday/this morning and would need some specific questions to hone in on. I hope this helps at least guide you in the right direction. ...and yes, I know the head unit is frustrating. This is just the initial reaction to so many options. Feel lucky you don't have the Carrozzeria RS-D7xII! You think our sources have options? PFFFFTT! That is one of THE most ultimate decks ever built. Think better crossover and optical out...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
