Old 08-04-2010, 03:52 PM   #8
pawngilly
Drives: toyota belta
If the hub is hot or warm , the different expansion of two different metals , aluminium and cast iron , creates a welding effect on the centring hole.
A bit of grafite grease helps the next time around , if rust is a problem. I used to have a VW camper , which I had to loosen the bolts half a turn and take for a short ride on the flat to get loose
pawngilly is offline   Reply With Quote
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
