Old 08-08-2010, 10:34 AM   #1
djct_watt
Drives: 2010 NCP91 5spd
And if this somehow is NOT a photoshopped picture, it probably implies a slightly revised Yaris hatch. . . I'm guessing that camo based on the existing Yaris hatch is too short, and it needed the extra length of the sedan to fully cover the car. This would be inline with moving the car's dimensions more in line with the Fit/Jazz (eeewwww).
djct_watt is offline   Reply With Quote
Old 08-08-2010, 10:40 PM   #2
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Yep, the Yaris evolution.It has a bigger boot (trunk) longer and wider.Toyota staying ahead of the competition.
Old 08-08-2010, 02:31 PM   #3
Kal-El
Kal-El's Avatar
Either way, the 2012 Yaris line will be all new. Not simply a facelift.
I'm expecting it to be more evolutionary than revolutionary this time around since this generation was such a leap from the Echo. But it will still be entirely new including a new engine and especially transmission (6 speed needed to compete with Fiesta and other upcoming models). Toyota MUST reclaim the title of the highest non-hybrid/micro-car MPG rating in the sub-compact class. That means a 41 MPG highway target. A tall 6th gear could easily do that even with no other changes.
Old 08-08-2010, 04:58 PM   #4
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
That's great! Just like the photoshop I did that one time! looks like someone glued the back of the hatch on!
Old 08-08-2010, 05:22 PM   #5
ERA
ERA's Avatar
Drives: '10 Zephyr Yaris Sedan
kind of cool looking
ERA is offline   Reply With Quote
Old 08-08-2010, 05:55 PM   #6
ERA
ERA's Avatar
tweaked it up a little.
Old 08-09-2010, 03:19 AM   #7
*MAD DOG*
*MAD DOG*'s Avatar
I don't like how the roof ends up like that in the back (see red section).
However ride height seems much improved (see yellow section)
To me the thing doesn't look right.
Old 08-09-2010, 04:38 AM   #8
The roof lines on the sedan and hatch are quite different, the sedan starts sloping back earlier white the hatch stays pretty much level. So, for this test car, they obviously slapped a hatch rear end on a sedan body and had to "connect the dots", so to speak!
It certainly does not look right, some Frankensteinian creation, which (hopefully) has nothing to do with how the next-gen Yaris will look like
Old 08-09-2010, 03:47 AM   #9
tomato
tomato's Avatar
^ that does look like a photoshop now that you mention it. You're right something is a bit off. I guess we'll find out soon enough
Old 08-09-2010, 04:19 AM   #10
djct_watt
Well keep in mind that if it is a real pic, this is definitely a test mule; so the real thing probably will look nothing like it.
Old 08-09-2010, 04:24 AM   #11
djct_watt
Man. . . I still can't see where people are seeing Auris parts in this car. . .
It's identical to the sedan in every way except for the C pillar back, where it has a hatch rear end slapped on.
Old 08-09-2010, 04:35 AM   #12
djct_watt, sorry my earlier reply was not clear, I 100% agree with you, and I think this quick and dirty animation will help demonstrate :)
Old 08-21-2010, 11:27 PM   #13
for those who missed it...
Old 08-09-2010, 05:41 AM   #14
djct_watt
^ thanks. And great point about the "connecting the dots." I didn't think about that. At first I thought it was under some kind of suspension testing and was being weighed down. But taking a look at how they line up, your point makes perfect sense.
If this is a real pic, we can guess that
1. Slightly larger cargo area (the biggest complaint about the Yaris)
2. Wheelbase similar to that of the sedan
3. Width close to current dimensions
4. Engine size not likely to be larger than 1.8L for high spec'd models
5. The 1NZ better damn be updated, it's an engine that's not aging gracefully
Old 08-09-2010, 12:44 PM   #15
slothman86
slothman86's Avatar
Nice work! I think this proves that someone just welded the lb back on a sedan... There are even what appears to be seams!
Old 08-09-2010, 01:10 PM   #16
djct_watt
Yes... If it's not a Photoshop, it still
Must be a test mule. The weird cut to the hood suggest something going on in the engine bay.
Old 08-09-2010, 03:21 PM   #17
we should also analyse the pictures to try and figure out where these pics were taken, as this might prove to be an extra clue as to the purpose of this vehicle. It's definitely in Europe from the other cars and their license plates, I would even say France, as the "Eskimo" brand of ice cream is rather well known, though I am not sure if it is sold in other european countries. And knowing there is a Toyota manufacturing plant in France that produces the Yaris (but AFAIK not the sedan), it is quite possible that Toyota is taking the cheap route to make an 'all-new' European Yaris by using the sedan as a base. But who, knows, really, that's my conspiracy theory
Old 08-09-2010, 05:14 PM   #18
slothman86
slothman86's Avatar
It has a strange light blue plate other cars in the pics show European plates.
What is this mystery plate!?
