Those sound about right. I haven't measured the voltage, but I have measured the resistance of the three taps on the resistor, which are 1.0, 2.0, and 4.0 ohms. The blower motor has a coil resistance of 5.4 ohms.
High completely bypasses the resistor, so if it sometimes doesn't work on high, then it's definitely not the resistor. I would check the contacts on the blower switch and also the HTR relay. |
| Tags |
| a/c blower resistor |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
| A/c blower motor noise!!!! | LBdriver | General Yaris / Vitz Discussion | 28 | 09-12-2007 07:46 AM |
| A/C blower | flighttekchris | DIY / Maintenance / Service | 5 | 08-25-2007 11:42 AM |
