Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 08-19-2010, 01:30 PM   #19
ubospawis
ubospawis's Avatar
Drives: Flint Mica 2010
Originally Posted by syntax View Post
@ ubospawis so nung naka todo ang A/C then wala ka nakikita na foam or bubbles then off mo sya wala ka pa rin nakikita na foam or bubbles?tama ba?
yes wala
ubospawis is offline   Reply With Quote
Old 08-19-2010, 03:35 PM   #20
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Ma-check nga rin si mica.
rye7jen is offline   Reply With Quote
Old 08-19-2010, 03:40 PM   #21
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Bukas sabay sabay tayo... pampa-ANING to!
jonimac is offline   Reply With Quote
Old 08-19-2010, 05:05 PM   #22
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
ayos
duke_afterdeath is offline   Reply With Quote
Old 08-19-2010, 05:09 PM   #23
duke_afterdeath
sa tingin ko good condition pa AC ni mica,, si storm 2 years na wala pang problema sa AC
ung naging problema ni storm sa fuel filter now ko lang naisip baka dahil sa paglagay ko ng 95 octane
Old 08-19-2010, 05:14 PM   #24
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
@syntax tama ka pag di malamig dalhin mo na sa shop para palagyan ng prion.kung bago pa yaris natin sigurado may leak dapat i pa check.under warranty naman
amaze_2 is offline   Reply With Quote
Old 08-21-2010, 06:03 AM   #25
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Possible kya ito?? Paki-confirm naman mga kayaris.
Old 08-21-2010, 03:02 PM   #26
duke_afterdeath
uu nga tama kaya palagay ko di ako mapalagay
Old 08-21-2010, 04:19 PM   #27
syntax
syntax's Avatar
not quite dahil possible causes ng baradong fuel filter at sirang fuel pump ay:
1. marumi na fuel
2. laging nagbblink na ung fuel indicator bago mag fill up
3. all of the above wahahahaha
Old 08-21-2010, 04:47 PM   #28
duke_afterdeath
1. marumi na fuel
uu nga pala, gawi ko nga rin pala b4 ung nagbiblink ng indicator bago ako pa gas..
Old 09-03-2010, 05:14 PM   #29
ubospawis
ubospawis's Avatar
one more test can be done
PRE (E8-6) - SG-1 (E8-11) GR - B A/C pressure sensor
signal
Refrigerant pressure:
normal 0.76 to 4.74 V
from http://www.yarisworld.com/forums/sho...t=29931&page=2
page AC-17
sino me multimeter? try natin check minsan?
Old 09-04-2010, 03:56 PM   #30
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
Just a sidenote, tip from my friend in toyota alj. Don't let your fuel gauge below 2 bars as earlier yaris has false fuel level or getting empty due to fault in fuel level and pump.
Its a good practice to fill the tank above 3 bars to have a clean fuel and at the same use stp injector cleaner every 10,000km just as they do in service center.
ricepower is offline   Reply With Quote
Old 09-04-2010, 04:16 PM   #31
jonimac
jonimac's Avatar
signal
page AC-17
Ako bro, sige dadalhin ko. @rye yung busina remember?, paki dala na rin.
Old 09-04-2010, 04:16 PM   #32
duke_afterdeath
tol yung stp injector cleaner yan ba yung sinasama sa fuel? meron kc akong nilagay b4 parang di stp yung brand, same ba yun?
Old 09-04-2010, 05:02 PM   #33
ricepower
ricepower's Avatar
basta injector cleaner preferably designed for fuel injected engines
Old 09-04-2010, 09:18 PM   #34
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@Joni, nasa car lang sya, cge chack na lang natin sa meet.
Old 05-21-2011, 05:21 AM   #35
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Buhayin ang topic na to! bwahhahahaha!!!
Dami na nating meets pero di pa ata natin na-try icheck ito?
Old 05-21-2011, 02:49 PM   #36
syntax
syntax's Avatar
@ rye ang tagal na ng thread na ito ahh.. na check naman natin diba?
Budget System Indianspringsaz In Car Entertainment + Electronics (audio / video / alarm) 19 05-25-2010 01:44 PM
Ford has a good idea. MyKey *MAD DOG* Off-topic / Other Cars / Everything else Discussions 16 03-19-2010 01:17 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
Updated Sound System. Twistoffate0817 In Car Entertainment + Electronics (audio / video / alarm) 21 09-16-2009 12:24 PM
Immobilize and security system. Meow In Car Entertainment + Electronics (audio / video / alarm) 19 04-18-2007 05:40 PM
