Drives: 2008 Yaris Join Date: Aug 2010
Driver's Door sounds hollow
Bought pre-owned 2008 Yaris and the driver's side door sounds "tinny". The passenger side does not.
Does anyone have a photo of what should be inside (between the interior door panel and the exterior door panel)? Something is wrong here. I think it was damaged, but it was not on the car fax report. There are shop rags inside of it, and a small piece of styrofoam-like panel. I think there should be more insulation. Thanks for anyone willing to help. |
Drives: 07 sedan Join Date: Mar 2010
sedan or hatchback? power windows?
There should be a plastic moisture barrier covering the whole thing for one. There's a little foam but not much. ... shop rags aren't stock :P |
Drives: 09 jetta tdi dsg Join Date: May 2010
both of the doors sound very tinny on mine as well, I'm pretty sure its a normal yaris thing because the others I test drove did the same thing as well. the rear hatch sounds very cheap as well when you close it.
#4 | |
![]() Drives: 2010 Yaris 5 door Join Date: Jul 2010
Dont know what the door should look like, but not all damage makes it to a carfax report. Generally only insurance claims do.
![]() ![]() Drives: 3dr Lftback (meteorite) Manual Join Date: Apr 2010
the whole car sounds tinny. that is the way they are made... there are folks here who have made significant improvements in bringing the noise levels down and specifically turning that tinny noise you have noticed into a very satisfying "thud" that you get with a more expensive vehicle. I will find a few that i have seen, just a sec.
Maybe the shop rags are someones attempt to deaden the door? |
here are a few that i have been following:
http://www.yarisworld.com/forums/showthread.php?t=26150 http://www.yarisworld.com/forums/showthread.php?t=27361 http://www.yarisworld.com/forums/showthread.php?t=24585 you don't have to do the whole car like these guys are. you can do just the doors and it will solve the problem that you have described. then if you see market improvement and catch the bug... who knows. :) hope that helps. let us know what you find/decide to do. |
My doors sound very "tinny" as well.
Installer
Drives: 2008 Yaris HB Join Date: Nov 2008
They are all very hollow or tinny sounding stock. Have the doors sound deadened well and you will not regret it. Sound deadening was one of my first mods to the yaris as i couldnt stand the crappy sound of the door closing. It also(if done correctly) dramatically improves the sound quality in the vehicle.
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Mine all sound like "thud"
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
It is a very loud highway car.
Making a decision without following it with an action is still a fantasy. |
| Drill hole in Driver's glovebox? | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 07-05-2010 05:26 PM |
| WTB: Driver's Side Fog Light | MadMax | Willing to Buy by private party | 7 | 12-20-2009 12:48 PM |
| And the worst drivers in America live in..... | KCALB SIRAY | Off-topic / Other Cars / Everything else Discussions | 12 | 05-22-2009 08:55 PM |
| WTB: Drivers Side Headlight LiftBack | Saggio | Willing to Buy by private party | 7 | 03-10-2009 02:21 PM |
| Intermitent problem with remote lock dosnt unlock drivers door only when it rains.... | YarisSedan | DIY / Maintenance / Service | 8 | 03-05-2009 11:41 AM |
