View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 08-29-2010, 06:48 PM   #451
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
CTScott, I use to use this mp3 player back in high school - http://asia.cnet.com/reviews/musicpl...6925p-1,00.htm
It used OLED technology and I was able to read song titles walking around the border of the school during lunch time in the sun.
I don't think it should be a problem i the YarGauge as well because the cluster sits a little angled down in the area, doesn't it? it isn't directly sitting flat per say....at least when you install/remove it, it mounts a little tilted...
Old 08-29-2010, 07:23 PM   #452
Originally Posted by sleey0 View Post
Unless it is Super-AMOLED, which I highly doubt, you have it backwards.
OLED displays are very nice and produce rich colors and deep blacks, but their worst flaw is daylight visibility, which is pretty weak. I wish OLED had great visibilty in the sun but they do not. The reason being is there is no backlight which is found on a traditional LCD. Instead, it uses a bioelectrical chemical to light and this washes out badly in the sun.
Just warning you before you make a mistake and buy them.
That was my impression as well. The VAR that is sending me the samples claims that they are a vast improvement over earlier generations of PMOLED displays. I guess we'll see. As Kioshi mentioned, the display is not in direct sunlight, so perhaps the high contrast ratio behind the smoked lens will do it. The gas gauge is just a backlit transflective LCD, but it is a higher contrast one than I've been able to source.
Old 08-29-2010, 07:29 PM   #453
Biff
Super Duper Biff Guy
Biff's Avatar
Drives: from here to there.
i'm in for one!!
Biff is offline   Reply With Quote
Old 08-29-2010, 08:53 PM   #454
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Originally Posted by Biff View Post
i'm in for one!!
You sure about that?
dont have anything to say about this ?
Originally Posted by sw07gt
Old 08-29-2010, 11:26 PM   #455
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
LOL unresolved issues?
Getting psyched this thing is getting close to completion CTSCott. I'm sure you'll sell a ton, to Garm atleast :P Hope it isn't hard to swap it in there.
Old 08-30-2010, 06:09 PM   #456
JumpmanYaris
USAF_SrA_E-4
Na, just has to say something always..
Old 08-30-2010, 06:54 PM   #457
Nexus1155
Drives: Audi
ah just looked up his posts... one of THOSE people :P
Old 08-31-2010, 06:05 PM   #458
Biff
Biff's Avatar
Yup, one of those ppl
Old 08-31-2010, 06:13 PM   #459
Biff
Biff's Avatar
What posts are you referring to? I don't know what you guys problem is.
Old 09-01-2010, 09:43 AM   #460
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Question
I'm sorry if this has been addressed already in the thread but I have a couple questions:
Will this work in a Canadian Yaris? I have a 5-door automatic with tach. I'm guessing probably yes, but it'd be nice to be sure.
Were you able to come up with instant fuel economy? Especially interested in L/100km if possible.
EDIT: I searched the thread and found both these questions were answered. Looking forward to seeing this project to completion, and likely buying up one myself if possible!
teddy is offline   Reply With Quote
Old 09-01-2010, 05:26 PM   #461
Revsson
Teddy -
Since you asked before searching, you have to go to the back of the line!
j/k ....or maybe not....
Old 09-03-2010, 11:01 PM   #462
I received my sample OLED display today and did a bit of experimentation with it tonight. The display is amazing on the bench, but they all start out that way. This display is a 16 bit color OLED display. For initial testing I am just running it with white text on a black background.
I mounted it in Crashy's cluster for a quick test and will put her cluster in my 09 tomorrow to do some sunlight testing.
Old 09-03-2010, 11:49 PM   #463
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
looks nice
mr9865 is offline   Reply With Quote
Old 09-04-2010, 12:04 AM   #464
auxmike
auxmike's Avatar
Small text, but it looks BEAUTIFUL!
Old 09-04-2010, 02:20 AM   #465
Nexus1155
Drives: Audi
kestion. Are the RPMs reflected in real time or have a slight lag to it like some digital rpm display readings?
Also, does the text change color :) or backlighting w/e?
Old 09-04-2010, 08:28 AM   #466
The text is actually bigger than the two prior displays that I tested. This one has programmable fonts, so I loaded a font that maximizes the space of the clock display opening.
The data is more realtime than other comparable devices, due to the speed of the CAN bus processor that I am using. The hysteresis of the display becomes the limiting factor.
The text can be any of 65535 colors with this display. The background can be any color as well, although the manufacturer recommends bright text on a dark background, rather than dark text on a bright background, due to a smearing effect that happens with OLED displays.
There's not a cloud in the sky this morning, so today will provide a good test for the sun glare visibility of this one.
Old 09-04-2010, 09:49 AM   #467
sleey0
Drives: 2008 Yaris LB
I am rooting for you.
Man, you are one intelligent person. Wish I knew how to do these things!
GL!!!!
sleey0 is offline   Reply With Quote
Old 09-04-2010, 10:01 AM   #468
Nexus1155
Drives: Audi
Just what I wanted to hear. I was also thinking color for those of us who want to keep it stock looking or go with our already red motif ;)
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 11:27 AM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 10:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 12:04 PM
