Originally Posted by Jitazuki
You are one swift man, sir.
Auxmike^
Mine are grey, where as yours are black. I think the one CTScott is mentioning is the grey one?
Both of our part numbers are for the "dark gray" color, which is nearly black. I am not sure why there are two different part numbers, but both are the same part/color. If you want to be sure about yours, you can just pull up the piece that those blanks are mounted to with your fingers, and check the part number on the bottom of one of yours. For the European Yaris, the only other part number I see is:
55539-52060-E4 which is described as "ash brown"
