Old 09-09-2010, 11:44 PM   #11
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
[QUOTE=derickveliz2;509663]
My amp put out 300 watts:
Bazooka is rated at 300 watts
Solo-Barics are rated 350 watts each
The guru expert guys may explain this better.
SMACK!
This is your problem.
You don't have anywhere near enough AMP to push 3 Solobarics!
You need a 900 watt amp on those Solobarics.
You put a bigger amp on those things, and you will see a huge difference.
300watts is good for one Bachuka.
I am putting 400watts on one Alpine Type-R.
And it's just enough!
I would run a 900 watt amp on 2 Type-R's.
Underpowered subs suck, and you can actually hurt the subwoofer by not giving it enough power.
Lots of articles on the internet about this.
One other thing: did you ever tell us anything about the BOX those Solobarics are in? Sealed or ported? What Ft^3 ?
Also, what model Solobarics? L5 or L7 ?
( L7's are bigtime power hungry beasts )
How do you have them wired up? What is the total OHMS load? Are they single or dual voice coil? What ohm per coil?
What is the RMS power rating of your amp at WHAT OHM LOAD?
You gotta match up these numbers correctly, or you will cook your amp, or severely underpower your subs.
How about a photo of them!
