Y4R1Z
SRS warning light and dealership fun :)
I spent 3 1/2 hours and $120 at my local toyota dealership today and they accomplished TWO things for me.
1. Replaced the top bolt on the alternator. Apparently I don't know my own strength and I weakened it enough that it broke off... while I was driving. I heard a rattle one morning and upon investigation I found the bolt head bouncing around on the plastic under belly. ( or it was a weak bolt in the first place... there was rust on the inside of it!) 2. Diagnosed the SRS warning light and informed me that I need a new spiral cable ( I think that's what they called it ) in the steering wheel column. A $312 piece of wire and plastic as I understand it. I asked them not to order that piece. I think I only got charged for labor and the diagnostics test. When I inquired about the warranty covering it they politely, but forcibly, explained why the warranty did not cover this. There was no rust on the bolt still stuck in the alternator. And the 60,000 mile/60 month Safety Restraint coverage only includes the physical seat belts and the actual air bag. It does not include any of the wiring or electronics involved. <- that's when I decided I still loathed that place as much as I did 4 years ago. Side note... I thought since they were going to take the alternator out anyways I could get them to install my other two pulleys for me while they were in there. I knew I would have to pay the labor charges for that extra, and I mentioned that as well. Turns out they were too *busy* to do that... I also asked if they could just show me how to get one of the wire connections loose, cause I can't figure it out. They wouldn't do that either because they were too *busy*. ![]() I say ALL of that to ask a question. Does anyone know where I can get this spiral cable for less that $312? And how can I replace this by myself? If it can't happen... I'll just be without airbags like back in the day with my '86 Crown Vic! And those two connections on the alternator. One of the just unplugs when u push the tab in. The other one has a gray plastic cap surrounding it. Can anyone explain how to get that off? I was afraid I'd break something if I kept forcing it and not be able to get it to reattach properly.
Here's a video that I put together on removing the headlight stalk, but it also covers removing the clockspring (spiral cable):
http://www.youtube.com/watch?v=LgWSzVeILhc I don't see any on ebay at the moment, but you can try car-parts.com to see if there is a junkyard with one. Out of curiosity, did they tell you what the actual error code was for the SRS? |
#3 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
Safety systems, from the sensor in the front to the airbag and all electronics that are part of the safety system, must be covered. go after them, but first check with your State and the laws and BBB and bring the hammer down on them. call the newspaper, write an email. make a fuss (but be nice) |
#4 | |
Only Happy When it Rains
Colin Chapman disciple |
oh the dealer came first. I mean the stories of what car dealers use to be able to get away with is just insane.
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I hate car dealerships. My Toyota dealer won't order parts for me. I gave them the part number for the double din dash and they said that "it didn't exist". They said there was no way to replace the factory radio in the Yaris. I showed them pictures from here of people doing it and they said that it must be a custom job. I was like wtfbro? and ordered one from somewhere on the Intert00bz.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
You see, my dealer here is pretty good. It really does vary from one to the next:)
I walked in one day with a TRD part, they have never seen me before ever, and I ask "hey got some time to put this on?". No appointment. He looks in the bay, says yep no problem. Mind you this was at like 4pm and they close at 5pm. Any time I go in there they are always good to me - and I didn't even buy my car there! |
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
my question, how exactly did the clockspring get broken? should not be possible unless it was taken apart(and then put back together wrong)
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
Y4R1Z
Well I have done plenty with my car dealing with electronic components, but I have never been inside the steering wheel column... Here's what it is on my invoice:
B SUP. RESTRAINT SYS. LIGHT IS ON. CAUSE: B1801 DTC OPEN CIRCUIT IN D SQUIB. 52TOZ12 SUP RESTRAINT SYS 115 CT 120.00 120.00 PARTS:0.00 LABOR: 120.00 OTHER: 0.00 TOTAL LINE B: 120.00 RAN DIAG AND FOUND OPEN CIRCUIT IN D SQUIB. REMOVED STEERING WHEEL AND CHECKED ALL CONNECTIONS, AND FOUND SPIRAL CABLE TO BE SHORTED. SPIRAL CABLE WILL HAVE TO BE REPLACED. EST TO REPLACE $392.85 Not sure if the diagnostic code is in there somewhere... but a short? Something like that should be an easy fix I would think. |
#10 | |
ekodrvr
i could see a snapped spiral cable causing an open like that... but how would it have snapped? and if it was not snapped, how did it get messed up? and IMO, this should be warranty unless this car was in a wreck...
Y4R1Z
no wrecks... unless u count a head on collision with a raccoon requiring a new bumper. But the light came on months after that incident :( I think it should be covered under warranty also. I'm gonna try calling some other dealerships in nearby cities and see what they say. Maybe send an email to Toyota or something.
ekodrvr
okay, if it has not been in a wreck, and has not had the column disassembled, then how exactly would that get damaged? perhaps a defective wire acting as a "fusible link" during the super low amperage system check...
side question, how many miles? also, what year yaris? not that it makes a huge difference, but just being curious...
#14 |
Y4R1Z
Purchased October '06. Model is '07 3 dr liftback. almost 58K miles
sent an email to Toyota 3 days ago. No response yet, might give them a call next week. I'm trying to get an answer from the company, instead of local dealer, on whether or not this clock spring is covered. |
#15 | |
ekodrvr
#16 |
Y4R1Z
Got a response! It is covered! Going to contact a different dealer and see about it getting it fixed then I'll go back to the original hometown dealer and show them the email just to let them know what's up.
#17 |
ekodrvr
congratulations on making the stealership do what is right...
| Ridiculous errors from the dealership | 08blackyari | General Yaris / Vitz Discussion | 25 | 09-11-2010 06:25 PM |
| '09 Fog light replacement | Mavix | Cosmetic Modifications (Exterior/Interior) | 5 | 10-07-2009 03:21 AM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
