Old 01-28-2007, 01:13 PM   #17
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Originally Posted by Galavoxx View Post
Both stock and TRD are gas/oil filled. The TRDs have nitrogen gas, probably at a higher pressure with a heavier weight oil. They are likely rebranded Gas-a-Just. Both the TRD and the OEM are made by KYB. Here is a blurb I just found:
These KYB Gas-a-Just shocks use higher gas pressure to keep your tires glued to the road. The KYB Gas-a-Just shocks' velocity-sensitive valving system adjusts quickly to changing road conditions for maximum comfort in any situation. Their monotube configuration eliminates aeration and foaming, their micro-smooth, hard-chromed pistons extend their life, and their seamless cylinders and eyerings completely eliminate seam failures.
So we can get an upgrade to the OEM shocks without paying the extra $$$ for the TRD logo. That's what I wanted to know!
Now, anoyone has any info on what would be the KYB equivalent to the TRD option?
Any one with TRD shocks that can provide the specs, p/n etc... to help find the KYB match.
Also, about KYB. It might not be the best shock performance wise, but I can tell you those are some long lasting and good quality shocks.
Teh Power Upgrade YarisKid DIY / Maintenance / Service 9 01-22-2007 01:56 PM
Shocks and springs Q grimez Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-19-2006 08:48 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
Security upgrade Ryu General Yaris / Vitz Discussion 7 05-09-2006 09:00 PM
