No. You have to use it to at least remove the old springs from the struts... not needed so much to re-install the shorter Tanabe springs.
You can rent one from your local parts store for 10 bucks. Do it the SAFE way, get a spring compressor. |
#2 | |
Break'em off some.
If you have air tools you can get the stock front springs off without a spring compressor. Have a friend secure the strut on the ground with his foot. Give yourself about 15-20 feet in case anything goes flying, and make sure no one is standing in front of the strut. Use an impact gun to remove the strut nut. The spring will pop off about a foot, and some of the little parts may scatter, just keep an eye on everything. I did mine this way and the nut rolled away. everything else was right there. Use common sence and safety and you will be fine without a spring compressor. If you are stupid, using hand tools, or don't have the proper room to do this, get a spring compressor. Ashley |
![]() ![]() ![]() Drives: 2007 Yaris Liftback Join Date: Aug 2006
paid $40.00 at auto zone for the spring compressor...when i took it back, they refunded my money...
Its Stock. |
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
lol stickin it to the man baby..........too funny.......its actually a good tool to have, especally if you got a lot of friends that are into cars.....
| Tanabe Strut Tower Bar Install & Review [pics!] | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 04-07-2022 08:46 AM |
| Springs - Tanabe DF210 or Tein S Tech | andylai2k | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 06-10-2007 10:22 PM |
| Tanabe DF & Strutbar install | mcdaddy | DIY / Maintenance / Service | 18 | 05-03-2007 10:57 PM |
| TANABE DF210 SPRINGS AVAILABLE!!! | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 08-05-2006 01:28 AM |
| Spring Install Price | redglare45 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-30-2006 09:32 PM |
