Roadrunner Jr.
Yeah....
That is where I went a little above and beyond the normal backyard install. There are indeed two wire junctions in the kicks. I completely relocated them up into the dash since there is PLENTY of room. On the driver's side there is a ground...I just replaced the ground with an 8 gauge one and bolted it into the chassis behind my mid bass pod. My pods are attached on both sides to the chassis with with OEM bolts (in OEM mounting points). You, however, can work around the wire cluster. Your mids are smaller than mine are... I can also send you a neat little link to show you how to do some kicks cleanly if you'd like.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
