Old 10-02-2010, 05:49 PM   #11
33OH
Drives: '08 Yaris
to get offset you need to measure backspacing and forward spacing. subtract the forward spacing from the backspacing to determine how far off "center" the hub is. then convert that into MM.
remember, a 7" wheel is closer to 8" wide.
Backspacing - 2"
Forward spacing - 5 1/4"
Subtracted: -3.25"
Converted: -82.55mm?
And yes - it is exactly 8" wide.
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Ideal Offset? 15x7 ET42 Wheels TRD_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-18-2006 04:12 AM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
