Old 10-09-2010, 10:16 AM   #1
bigdoglover
Drives: 2007 red lb
07 liftback auto trans with about 33,500 no problems yet-bought her new. only have needed to do oil changes, tire rotations and just replaced the wiper blades. currently getting appr. 39 mpg in chicago suburban driving, no expresssway driving.
bigdoglover is offline   Reply With Quote
Old 10-09-2010, 02:36 PM   #2
wooverstone8
wooverstone8's Avatar
I purchased my 2009 Yaris LB new and so far the water pump and the water pump belt had to be replaced with only 16k miles on the odometer. I had to bring my Yaris back to the dealership three times after the water pump replacement due to coolant leaking. After three trips to the dealership the problem still hasn't been resolved since I've been forced to refill my coolant reservoir once a week due to coolant lost.
Old 10-09-2010, 05:40 PM   #3
sleey0
Drives: 2008 Yaris LB
That is lemon law.
Tell them to give you a new car
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-09-2010, 06:06 PM   #4
silver_echo
ekodrvr
silver_echo's Avatar
wa has a lemon law for that... it they cannot fix it, they need to replace it...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 10-10-2010, 07:43 PM   #5
wooverstone8
I've been carefully documenting everything after my 4th visit to Toyota of Olympia dealership. I don't think my Yaris is a lemon at this point, but I think it's just carelessness of the Toyota of Olympia dealership techs (the mess they left in my Yaris). The dealership claimed that there is nothing wrong, but air pockets in the engine?
Old 10-09-2010, 03:37 PM   #6
Lucas13
Drives: 07 Yaris LB
Mine with 62k
-Two front seats replaced almost entirely
-Exhaust mid section replaced due to faulty catalytic converters
-Water pump started leaking at 56k
-Manual Transmission replaced at 58k
-Passengers control arm need replacing now, I'm waiting until is destroyed to change it.
There are many other small things that I experienced with the car, I understand is a cheap car but with other cheap car I owned in the past I have never seen so many issues one after the other. I think I'm still going to keep it because I have spend to much of my time getting it to work fine.
Lucas13 is offline   Reply With Quote
Old 10-09-2010, 04:53 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by Lucas13 View Post
Mine with 62k
Wow, sorry to hear all of your issues that you have encountered. I think that you perhaps got one of the few lemons.
I have 43k over the 4 years and items that have been dealt with outside of personal upgrades are the following:
1) ABS Sensor per TSB
2) Door pillar insulation per Safety Bulletin
3) Missing Cabin Air Filter from dealership...did a DIY Filtrete
4) Reset ECU done by dealership since my gas mileage was all over the map last winter. One tank I could get 34mpg and the next 17, then the nextx could be 25, then 32. Once the dealer reset my ECU and it relearned the mapping it has done great. Might have been because it sat for a year while I was in Afghanistan without a battery.
5) Stock battery died 100% after 3 years. This must have been due to my stereo system hammering the crap out of it.
Oh yeah, and for some reason I have had to put new oil in it every few thousand miles...what is up with that?
Old 10-10-2010, 01:45 PM   #8
Lucas13
Drives: 07 Yaris LB
I have no doubt that my Yaris is a lemon or maybe a Tangerine!
I had my A/C drain clogged up too because of the lack of air filter, which for me is totally dishonesty from Toyota of not throwing that filter in they must know what happens without one...
I think you battery went t out like mine and many of the rest, they last about three years, the oil thing doesn’t sound that good with only 43k, you have car checked for leaks or something, an engine may consume some oil if you drive it too hard all the time.
A Daewoo I owned like 4 years ago was supposed to be a piece of crap and turned out much better than my yaris, I put 120K on that thing and all I did was basic maintenance. I’m sure the yaris is the last Toyota I will have.
Old 10-10-2010, 02:20 PM   #9
fnkngrv
fnkngrv's Avatar
I was being silly with this one. I know that there are those out there that would flame me for it however I change every 7500 miles right now. I have been ASE certified since 1995 and have always been a firm believer in the right products can go a long way. Once my turbo installation is in place then I will probably reevaluate my consumption however with how cheap the motors are for this car at this point if I blow it up then I will just pick up another one. I plan on picking up another one to slowly rebuild it anyway for greater performance.
My parents always bought Nissan and Toyota growing up. For the most part the only issue had been how both manufacturers had issues with the body rusting out well before the mechanical would give. That really isn't the case now. I have had my share of lemons...or should I say lemon lines? 86 Escort, 88 Plymouth K car, and 1990 Cutlass calais S -442 model with the infamous Quad Four. Nothing for nothing, but if you notice a trend there all 3 cars were from the Big 3 and they were all infamous for being lemons. Nuff said on that one.
Old 10-12-2010, 01:02 PM   #10
Eatoman
Eatoman's Avatar
Drives: '07 Yaris 5dr HB
Mine with 62k
Guess all Yaris's aren't made perfect...I just hope my Yaris lasts as long as my old car...a '97 Geo Tracker. After 13 long years of daily driving that little Tracker never let me down. Finally decided it was time for a change, so I settled on a Yaris. Guess I'll have to wait and see how this little car tackles these crazy canadian winters!
Eatoman is offline   Reply With Quote
Old 10-17-2010, 11:04 PM   #11
Lucas13
Drives: 07 Yaris LB
Not all the Yaris have all the things I’ve had with mine, they have the common problem such as the Water pump going bad soon. Right know I’m hopping everything goes well, I need to fix my right control arm and I hope that’s it for while will see
Old 10-20-2010, 12:25 PM   #12
Eatoman
Eatoman's Avatar
What exactly is a "right control arm"? Is this a costly repair?
Old 10-20-2010, 09:39 PM   #13
Lucas13
Drives: 07 Yaris LB
It is exactly what severous01 Explain, In my case the Lower Ball Joint (attached to the wheel hub) seems to be the responsible one that makes a hard noise when braking a little bit hard.
The Dealer quoted $564 and I told them , I'll change it by my self, With an after market part and aligment will total $160 I will save $404 not bad...
A decent shop with aligment included may not be as expensive as the stealer!
Old 10-10-2010, 01:10 AM   #14
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
55k on my 07 sedan, only problem has been strange fuel gauge, use tripmeter now.
Toyota reliability? Really find a Toyota with much more than corrosion problems, there were plenty of them in times gone by, not so much now.
Old 10-10-2010, 01:28 AM   #15
tomato
tomato's Avatar
Close to 60K, no problem.
Old 10-10-2010, 02:22 AM   #16
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
About 30K miles on a 2007.
(Single guy for the last two years. Guess that explains the low mileage. )
It's a bigger piece of shit than my Sunfire ever was - and I drove the crap out of that car, unlike my Yaris!
firemachine69 is offline   Reply With Quote
Old 10-10-2010, 11:50 AM   #17
Hershey
2 oil leaking head gaskets . Not good . The '08 sedan now has an issue where the dome light won't come on when opening both passenger side doors .
Old 10-10-2010, 11:10 PM   #18
SimTronik
Machinist
Drives: Yaris sedan 2010
I'd like to know.... where is the limit for pushing the car. I mean, when i drive and i do fast acceleration and i reach 6k rpm i feel like the car can barely take or like i did something not so good for the car. Im i thinking wrong?
SimTronik is offline   Reply With Quote
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
