Old 10-07-2010, 08:39 PM   #1
chilly79
Drives: 09, 3dr, LB, Carmine Red
OK I got my speedo working again and I was able to remove the LCD odo. When I got to the PCB I saw the lights and my thought was to remove a light from something like the windshield wiper fluid spot then solder it to the check engine. That did not work. I have done some soldering before but never on something like this. What I am use to is the lights that have wire that go through the board. Looks easy enough to put one on but I can't get one off. Since my thought is to reuse it I did not want to break the light. So at this point I guess I will just order me some lights and put new ones on. I know how to take it apart now so might as well. Guess I will go ahead and change the other lights out as well.
chilly79 is offline   Reply With Quote
Old 10-07-2010, 08:51 PM   #2
The LEDs require proper polarity, unlike a bulb. Try flipping around the one that you soldered in. Getting them off is much easier with a soldering iron made for surface mount parts, with a tweezers end which heats both sides at the same time.
Old 10-07-2010, 11:25 PM   #3
chilly79
I know about the polarity I just never got one off and don't have any new ones yet. I will have to go look different soldering irons. I just got one from Radio Shack. I did not see any like you described.
Old 10-07-2010, 11:33 PM   #4
Radio Shack is pretty worthless these days.
This is probably the cheapest one out there:
http://www.mcmelectronics.com/produc...LAID=220244277
