Old 11-03-2010, 09:30 PM   #1
RedRide
RedRide's Avatar
Can't you reset the ECU by unplugging the battery for a while?
Yes, that will set it back to the default setting.
BTW..... Something just occured to me.
I frequently access WOT as I'm not concerned about fuel economy. Even at its lowest, it's good enough for me.
So maby if you are constantly driving for economy, the ECU might be getting programed with some throttle lag to increase gas mileage.
This might explain why I don't have any lag.
It would be interesting to know how people drive and how it realtes to throttle lag.
Old 11-07-2010, 07:03 PM   #2
Al_
Al_'s Avatar
Drives: 2010 1.3L man
It is an issue with DBW as said before but not a big one, the lag on mine is something like 1/4 of a second and the easiest way around it is to wait until your foot is off the accelerator until pressing the clutch.
If you are a slow shifter then you won't even notice it it's that small, even I only notice it when shifting it's small enough that when going from coasting to accelerating I don't notice any lag.
The light pedal is just something you will get used to as you drive more, you could try wearing shoes with thinner soles.
Al_ is offline   Reply With Quote
Old 11-09-2010, 06:12 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
the Genesis Coupe is plagued by rev-hang.. the reason it's noticeable is because the car actually has power :) a reflash solved this problem on the genny and also gave us an extra 60lbft of torque.. can't touch that with ANY throttle-control mod for the yaris :(
Old 10-06-2016, 11:41 AM   #4
detergentthief
Drives: 2008 yaris
Just stick a sponge or a stress ball underneath the accelerator. Works for me.
detergentthief is offline   Reply With Quote
Lexus IS250 gas pedal + Lexus IS Sport Pedals/deadpedal Gideon Cosmetic Modifications (Exterior/Interior) 15 10-04-2022 02:50 AM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Gas pedal fmicle DIY / Maintenance / Service 12 03-31-2007 12:08 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
