#775 |
#776 |
Not a lot of progress this weekend, my sons birthday and many other things going on, but here we are after 4 or 5 sanding sessions...
Also in the background started to fill in the gap between the a-pillar and sphere, got some "thread-serts" too (for the speakers.) ![]() D. |
#777 |
Roadrunner Jr.
mmm...
Perhaps I should have bought the thread serts that use the allen wrench to insert them for you...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#778 |
How do I cover the a-pillar with speaker grill cloth or any other cloth? ![]() do I use spray 77 before all over the a-pillar? or just behind where it bends? Thanks D. |
#779 |
Roadrunner Jr.
Negative ghost rider...
attach the cloth to the back. What you're doing shouldn't be covered by grill cloth IMHO. It should be painted. I say that we should look at it when we actually get there. In the mean time, how are the spheres looking?
#780 | |
But like you said we'll look at it when once I get there. The sphere are coming along, I'm about to apply a thin layer of primer and get an idea of the surface. D. |
#781 |
PD... The sphere will be painted! I only want to cover the a-pillars !
#782 |
Roadrunner Jr.
Akkk! Dash mat material? That's a bit thick and farily non flexible compared to grill cloth. It'd be hell to get onto the pillar around the sphere.
#783 | |
So if I cover the a-pillars the spheres go on top, and my questions is that when you cover the a-pillar do you spray glue every where or just behind where it bends? my guess is everywhere they make contact??? ![]() I've been looking for DIY but no success ![]() Thanks D. |
#784 |
Roadrunner Jr.
I'm saying that the dash mat material is too thick. Grill Cloth is sufficient.
no, you wouldn't spray all over the pillar for the simple fact that the spray glue will seep through the material. Now, if you use the dash mat material, think about your pillar edges. They're going to show. You don't want that. While the spray glue won't seep through the dash mat material, it will on the grill cloth. Now, think about how with the thinner material you'd attach it to the pillar? I know the answer...I want you to work it out in your head.
#785 |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
SQ you are tough. lol. I don't know what you use but we use hot glue. It is perfect for attaching grill cloth to plastic.
#786 | |
D. |
#787 |
Thanks Palmer!!!
#788 |
Matching the base of the sphere against the a-pillar it's turning into a big challenge! ![]() ![]() After some sanding... ![]() ![]() ![]() ![]() NEXT STEP... MORE SANDING!!! |
#789 |
The hot glue we use is black and holds up very well to heat. You're welcome for the shirts. SQ has one coming too.
#790 |
Roadrunner Jr.
Hot glue...standing up to the heat?!? Seriously? Not so much. Hot glue is great for the initial tack. I know i used it to hold my tweeters in place...silicone or epoxy is even better if you're holding something that you don't want released. Another idea is staples.
I know about the swamp ass heat in NC...actually GA...it gets nashty in the summers. Hot glue will start flexing and coming up in the heat of a car's interior in the summer. If that cloth is tight the resistance can take up the ends. Hot glue will become viscous when subjected to heat. On the other hand, maybe I'm using the wrong hot glue. I dunno.
#791 |
Mabye you are using the wrong glue? We use it all of the time here and never have it come back for warranty. The stuff we use is black but I don't know what brand it is.
#792 |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
I've used the clear hot glue to try and immobilize my sirius radio windshield suction mount from shaking and in the summer the glue melted and dripped all over my dash board. That black stuff must have a MUCH higher melting point, and thus need a hotter glue gun to use?
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
