Old 11-25-2010, 01:54 PM   #34
H3LlIoN
Drives: '09 Yarrrr hatch
This thread is full of douche.
OP - It should...what you are describing sounds like the ECU going back and forth between open and closed loop modes, so if everything is plugged back in, it should take back over. Also, you don't have to remove the AFR sensor you added, as it should not interfere with your O2 sensor.
As for your install, it's a mess, but I'd imagine you probably don't have the resources there that we have here, so congrats on getting it together and running man. Keep it up.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Plan to install hks turbo kit on 1szfe Faraz_Shaikh Forced Induction Forum 5 10-19-2010 11:00 AM
Greddy Turbo installed Bluevitz-rs Forced Induction Forum 22 09-03-2010 10:51 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
