Old 11-30-2010, 01:54 AM   #1
pjh
Drives: 2006 Yaris HB
Hey guys, just got a (stock) 2006 Yaris HB and thinking of doing this mod. How much does this mod (for both 19mm and 23mm) affect the understeer/oversteer balance? I'm looking to reduce the understeer and improve turning response, but I don't want it so extreme as to be losing the back end regularly. I don't want my wife to drive it and end up backwards in a ditch. My gut feel is that this won't be a problem, but does anybody have a comment from experience on how extreme the two sizes are with respect to terminal understeer/oversteer?
Also, anybody have experience ordering to Canada from MI?
pjh is offline   Reply With Quote
Old 11-30-2010, 04:44 AM   #2
ddongbap
Yes. Garm will get it done for you. He ships worldwide.
Old 02-12-2011, 08:03 PM   #3
sickpuppy1
Drives: 2010 Yaris Sedan
They are both good bars. if your wanting to just get rid of some understeer (and as a side benefit, make it less susceptible to cross winds, or big trucks and such) I would go with the 19MM if its a 3/5 door. If you want to really"go for it" then MAYBE the 23. I have a sedan and the 19mm by ultimate racing (microimage) It is definitely a vast improvement, worth every penny. That being said, if I did it all over again, with a sedan, I would go with the 23mm in a heartbeat. More overhang off the back end (sedan) would benefit more from the 23 than a 3/5 door would, without worrying about oversteer. Like I said, I love the difference over stock with my 19 but feel I could have gotten even better without sacrificing any ride or stability. I have wood plank ramps I use for oil changes. I just put them under the back end and drove it up on them. Basically a four inch rise. Didnt have to take offs wheels at all.
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
