Old 12-07-2010, 11:00 PM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Check the bulbs first. It's not that likely that they both failed, but is worth a look.
Check the two H-LP fuses in the under hood fuse panel.
Check the ECU-IG fuse in the under dash fuse panel.
I can't stress this part enough.
Oh nuts you already checked. Would a beefier fuse solve this problem? CT? I'm genuinely curious
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
aftermarket headlights be_ha Cosmetic Modifications (Exterior/Interior) 0 10-03-2010 03:06 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
JDM headlights yrsdrgn Cosmetic Modifications (Exterior/Interior) 6 02-13-2007 10:52 AM
