Old 12-11-2010, 12:48 AM   #33
MadMax
MadMax's Avatar
Folks, Orange, California is in the southern part of the state (think Orange County), and they've been having the same temperatures as we have here in southcentral Texas...lows in the upper 40s/low 50s and highs in the upper 70s; so I don't think it is the weather causing this!
And while you will get reduced mileage out of bigger, wider tires, it won't drop your MPGs down that far. I still get 35 MPG average out of Sprocket with the wheels in my avatar, and mine is an auto as well.
The issue has to be these extremely short commutes, there is just no way the car can run efficiently during this brief duration and with all the stoplights, the odds are against the OP.
Winter gas can be a factor as well as I usually see a 2-3 MPG decrease when they switch over here. There's nothing you can do about it so don't worry about it!
What the OP needs to do is take it out for a good, long drive! Go away on a day trip and see what kind of mileage you get during that. Fill it up before leaving, reset the odometer and fill it up again when you return and divide the number of miles driven by the amount of gas that you put in. I will bet you get in the mid-30s are well, maybe upper 30s depending on where you go.
Let me ask this, did you drive this same commute in a different car before your Yaris? If so, what kind of car was it, and what kind of gas mileage did you get?
Cheers! M2
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 12:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Help me see 55 mpg! Loren Fuel Economy Forum 76 04-02-2009 04:23 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 05:48 PM
