Old 12-17-2010, 05:49 PM   #12
Happy Little Pony
Drives: 2007 Yaris HB
Most of the gunk in a gas tank is actually rust and corrosion from the tank itself. The Yaris has a plastic gas tank. No metal means no rust. Any fuel you put in should be getting filtered at the pump.
I personally like the idea of having a user changeable gas filter, but I've never actually needed to change one because it was clogged. Toyota obviously feels that the small amount of foreign matter introduced into the tank can be handled by the built in filter for the life of the car. Unless something goes dramatically wrong, they're probably right.
Happy Little Pony is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 02:22 PM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 11:40 AM
