Old 03-18-2014, 12:08 AM   #1
Tylard
Drives: 07 Yaris
Interested in purchasing
Do you still have any these?
07 sedan m/t. Cost as well. Thanks
Tylard is offline   Reply With Quote
Old 03-18-2014, 06:20 AM   #2
Yes. PM sent.
Old 03-21-2014, 09:52 AM   #3
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
ive got a 2007 sedan, can you pm me with the price and what i would have to do to install? thanks
z0mb13k1ll is offline   Reply With Quote
Old 03-21-2014, 10:34 AM   #4
PM sent
Old 03-22-2014, 07:11 PM   #5
Tylard
Drives: 07 Yaris
Super fast shipping, install not too bad, fishing the wires was def the hardest part. But I cant seem to get it to function on my 07 m/t sedan. I have tried rechecking all the connections and triple check the clutch switch to ensure it is fully pressed in when the my foot is off the clutch pedal.
Any suggestions of what to check?
My wire coming out of pin 40 on the ECM is hooked up and ran through the firewall. I connected this directly to the wire coming out of the slot 1 of the D3 connector. Is this ok or do I need a different wire? If so what is it where do I get it
Old 03-22-2014, 07:17 PM   #6
Double check your pin 1 and pin 2 locations per my DIY (http://www.yarisworld.com/forums/showthread.php?t=33750)
Also, with the ignition switch in the ON position, you can measure the voltage on the pin1 wire and will see 12V if it is connected properly. (Pin 1 is the one that goes to pin 40 on the ECM connector).
Also, double check your pin 40 to make sure you didn't install it on the opposite side of where it belongs.
Old 03-22-2014, 09:02 PM   #7
Tylard
Drives: 07 Yaris
Checked pin 1 and 2 and Im happy with them. Rechecked pin 40 also happy with that.
Checked the voltage. I put my red lead on the connection between the pin 1 wire and the pin 40 ecm wire. Then I put my black lead on the bolt where pin 2 from the d3 connection is mounted. I get 12 v with the ignition turned on. Holding and toggling the cruise on/off switch does NOT make change and still reads 12 volts.
Where the pin 2 wire is mounted there is a black lead already connected to that, I just added on the pin 2 wire and put the bolt back on.
Old 03-22-2014, 09:49 PM   #8
Ah, the pin 2 wire is the "other side". It is the ground for the system.
The black wire is not pin two. It is in the opposite row from pin 2. In this picture you can see the blue wire in pin 1 and the brown in pin 2:
Old 03-22-2014, 09:58 PM   #9
Tylard
Drives: 07 Yaris
My D3 connector looks just like the one pictured. The wires sent are different colors but going off the colors shown in the picture. The blue one connects directly to the A21 pin 40 wire. The brown one goes to a bolt (for grounding).
Old 03-22-2014, 10:00 PM   #10
Tylard
Drives: 07 Yaris
"4.8. Splice the ECM pin wire to the piece of 18-22 AWG wire using a butt splice or
solder and heat shrink tubing."
Do I really need to do that because the wire you sent me is long enough to reach the D3 connector.
Old 03-22-2014, 10:08 PM   #11
No. They are long enough to reach with how I ship them now.
Old 03-28-2014, 07:14 PM   #12
Tylard
Drives: 07 Yaris
Got the issue resolved, I now HAVE CRUISE!! Pretty sure this just doubled the value of my car. So happy about this.
Old 03-28-2014, 07:15 PM   #13
Tylard
Drives: 07 Yaris
And buy your stuff from CTScott. He does all the BS work so you don't have to and everything comes ready to hook up. Fast shipping, good customer service, and it was pretty fricken cheap too. Scotts the man.
Old 05-26-2014, 02:51 PM   #14
OldTimer
Drives: 2008 Yaris
I ran across this forum while searching for a solution for a Yaris without cruise.
I'm needing to make twice weekly 250 mile trips and unfortunately am finding it
difficult keeping a constant speed with old worn out feet and legs.
I have an 2008 Yaris hatchback (base) with a manual transmission.
Are the cruise control kits still available?
Thanks
OldTimer is offline   Reply With Quote
Old 05-26-2014, 06:20 PM   #15
nortonfb
Drives: 2007
CT Scott has them. Drop him a PM.
Steve
nortonfb is offline   Reply With Quote
Old 05-27-2014, 01:18 AM   #16
OldTimer
Drives: 2008 Yaris
Thanks
Old 04-22-2015, 01:37 AM   #17
YAR1S
YAR1S's Avatar
OK scott ..... might tackle this in the next month....
message me info on buying the kit for a 2007 (power package?) AT Liftback
Thanks!
-Jen <3
Old 08-20-2015, 10:11 AM   #18
hayden
Drives: asd
Hi Scott - previous customer here, now with an automatic 2014 2DR. Would the kit you sell work on my 2014 as well? Would love to get CC installed on it. You mentioned in the other thread that the 2015 doesn't require additional wiring, is that true for 2014 too? And by that, do you mean I just plug in the OEM stalk and the rest of the wiring to the car's computer is already there? If so, that's very nice!
Let me know where to Paypal!
hayden is offline   Reply With Quote
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
