#127 |
![]() ![]() ![]() Drives: 2010 Yaris "5-door" Join Date: Mar 2009
Yeah, I definitely don't have as much control while shifting gears when I'm wearing my boots - my "touch" with the pedals is all wrong.
#128 | |
Drives: 07 sedan Join Date: Mar 2010
#129 |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
When myth busters ran the A/C vs windows down show...shame on them. They used Ford Exploders or something larger. They get the same mpg no mater what the condintions. Read terrible. If they used a genuine fuel efficient vehicle they would have had a better test. I had a 1989 Subaru Justy w/ a CVT. If the tire pressures dropped a few, I lost MPG. I got high 49 mpg on a road trip once. A pluged air filter showed a few mpg loss. The Yaris is such a vehicle. I do not use Scan Gauge. I have kept a log of all the gas through the thing since I got it. Overall to date is 39.8 iirc. High single tank is over 44.
doc Last edited by docB; 09-05-2010 at 08:57 PM. Reason: spelling/key board |
#130 |
![]() ![]() Drives: 2008 yaris sedan Join Date: Jul 2010
The Ac efficiency on the Yaris really impresses me, I have compared my mpg
with it on or off,and I can Say that I have seen very little difference if any at all, compared to other cars I have owned in the past this is big Improvement. On the Interstate highway With Ac on and roof rack and surfboard {9 1/2 foot longboard} averging 73-76 mph I still easily get 37/38 mpg I am quite happy with that. Last edited by krolos; 09-26-2010 at 09:03 AM. |
#131 |
Drives: 08 Yaris Sedan Auto S Join Date: Dec 2010
Just bought my 08 Yaris sedan a couple of weeks ago for its supposed gas economy. I have now filled up the tank myself 2 times but have only seen 32/33 MPG. I was so excited to get 35-40+ MPG and am extremely disappointed. The car came with only 17,000 miles on it and as far as I could tell, was very well maintained.
My daily commute is 40-50 miles a day with 25 miles being on the interstate going 75 mph and the rest being dirt roads or city driving. Would the dirt roads make a big difference (going 40-50 mph)? However, I was able to take small trip (400 miles roundtrip) that was 85% interstate driving at 75-80mph and the rest city driving--was ONLY able to go 325 miles before having to fill up (gas flash came on) for a rate of 32 mpg. Last night I filled up all of my tires from the dealers 30 psi to 35.5 psi. I also filled my gas tank at the same time to see if this would make a noticeable difference. Too soon to tell yet, but would love to have some advice on how to maximize my fuel economy so that it gets at least 35 mpg. I bought the car thinking that 35 mpg would be the minimum due to many of the reviews I read of people stating they get 40+ mpg consistantly. Other factors: Nebraska weather has been 15-30 degrees since I have bought it and thankfully no snow or inclement weather...yet. I am also not the softest driver ever, but since buying the car have tried to be gentler but I am definitely a work in progress :) Would appreciate any help or ideas! |
#132 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
![]() The Yaris is EPA rated 32 mpg combined (29/35). So if anything, it's perfectly normal. Why are you shocked? Also, it is winter and as you pointed out really cold. That drops mpg significantly. Wait until spring to really take a good look at what your MPG is. The fact that your drive is half city and dirt roads should be a clue that you're not going to get 40 mpg. In your described conditions, you'll never get into the high 30's. That's perfectly normal and there's nothing wrong with your car.
#133 |
#134 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
cold air kills mpg.
#135 |
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
This is a significant factor in why your gas mileage is not as high as you would like to see, most likely your chief reason, actually.
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
#136 |
![]() ![]() ![]() Drives: Loaded 2007 mica silver sedan Join Date: Sep 2007
with winters here in New Hampshire my mpg drops about 5 to 7 mpg. Longer warm ups to get the car to operating temp and I run four snow tires. In the winter I get about 32 to 34 mpg but during the warmer summers she goes up to 38 to 42 mpg.
#137 |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
I got enough warm weather miles on my recently bought '08 to believe the high MPG #'s, 38 to 45 with an average of 42 between fillups. A few miles of dirt road every day, with the rest freeway (60+ max) and 45 on the secondary roads.
Now that winter has really hit, and I have to have 4 wheel drive (busted through a 24" drift yesterday) I am back in the good old '89 Toyota All-Trac. I have yet to check a tankfull using the winter gas, when the weather improves I'll start driving it again, but I fully expect the MPG to be lower, due to the factors stated by others, but it will still be better then about anything else out there! |
#138 |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
Cold air does not kill mpg... moist air does. Cold air is more dense than hot air (the reason behind inter-coolers) and fuel burns more efficiently. Cold dry air gives mpg a noticeable boost, the car is even a bit more powerful with cold, dry air.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#139 | |
![]() Drives: 2007 Yaris Sedan, 4-spd auto Join Date: May 2011
#140 | |
Austin |
#141 |
I ♥ Yaris
No, cold denser air helps mpg. For simplicity's sake lets say you need x amount of hp to maintain whatever speed. With hot air, the engine has to use less fuel per stroke, because the lower oxygen level but in order for the engine to output the proper hp and maintain the speed, the rpm has to go up. With the higher rpm being used to maintain the same speed, the hotter air gets worse mpg. Sure it uses micro-grams less fuel per stroke per cyl with the hot air, but every single additional rotation that it has to use to maintain hp uses an additional unit of fuel in each cyl...
#142 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
The RPM is related for the most part to the gear and the speed you're at. Most of us see the best mileages over the summer months. And this is even with the gas ratio changes some states are required to do.
When you get cold air, the computer has to compensate for the denser air...meaning more fuel to keep it at the ratio the computer thinks it's supposed to be. If you want more power, sure take in colder air but that is not the route for getting better mileage.
#143 |
![]() ![]() ![]() Drives: yaris 2 door hatch Join Date: May 2007
texas wide open 75 mph most of the time. I average 36 mpg this car made to drive.
#144 | |
0-60 IN UNDER FIVE
Drives: 2008 Blk on Blk Yaris Sedan Join Date: Feb 2011
| Is the yaris best car for gas mileage out there? (in it's price class, of course) | BennyLava | General Yaris / Vitz Discussion | 17 | 02-10-2010 06:33 PM |
| TO ALL PEOPLE THINKING OF BUYING A YARIS | markpeppie | General Yaris / Vitz Discussion | 43 | 08-20-2006 08:27 PM |
