Old 01-15-2011, 05:21 PM   #11
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Originally Posted by cdydjded View Post
Dont worry about the scavenge pump. It really doesnt apply to your issue. You oil feed line should be a -3 or -4 hose & your oil return should be a -8 or -10.
Here is a pic of the oil feed pressure restrictor:
Attachment 39382
This lowers the oil pressure going into the turbo. You dont need any more than 30-40psi of oil to go into the turbo.
Question. What if the restrictor is placed not on the turbo itself but from the feeding source and the the feed line run from it to the turbo. You should get the same pressure through the line to the turbo right. Reason i ask is that it would be a real pain and much labor for me to take out the turbo to put the restrictor on it. I would rather put it on the source.
Yoda is offline   Reply With Quote
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
