![]() ![]() Drives: yaris advance Join Date: Jan 2009
Spark plugs
Hello people, what would be the best set of spark plugs to install on a 2008 yaris, besides the OEM?
Here we go...
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
how abour some equivalents from NGK from autozone....why pay 30 bux a plug at the dealer when you can get the SAME EXACT PLUG from autozone or orileys for about 6 bux each...
Stick with OEM. Dont they say they are good for 100K?
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
I went with denso iridium spark plugs. It idles much better with the A/C on. It dosen't feel like it is going to stall anymore. I got them at Discount Auto Parts for 7.99 if I remember right. NGK also makes a similar quality plug. I would not buy anything that is not iridum though. Replacing the spark plugs on the Yaris is so much easier than on my Dodge Ram. You will need a 6" extension to reach the plugs.
Either Denso or NGK iridium plugs are fine
Actually, Toyota uses NGK on ocasion In fact, my Celica came with NGK iridium plugs. |
heyyy...try splitfire....g
ooooh oooh.....E3 plugs are good....for a lawn mower...(does a yaris count as a mower?)
or you can always put PULSAR on the yaris. they're 25 a pair though...and 30 for the iridium |
Ok it seams that DENSO or NGK, thank you for the advise, since my idle with the a/c is not as smooth as it used too be, I´m goit to replacement them, and it is time too.
NGK only...that or denso, or Delco, which is usually made by either denso or ngk...depending on style and make.
i wouldnt put champion in my lawnmower, and i wouldnt use autolite in my enemies' lawnmower. |
| spark plugs | phenoyz | DIY / Maintenance / Service | 48 | 01-18-2023 02:26 PM |
| Spark plugs for yaris RS 2zrfe engine | candy_red | Yaris TS Talk | 3 | 11-16-2009 01:20 PM |
| article on spark plugs and the fit | kngrsll | Performance Modifications | 4 | 08-01-2009 11:50 PM |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 02:07 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
