Old 01-29-2011, 01:42 PM   #4
severous01
if your'e doing the 10mm inthe rear why not do the penguin spacer back there and not between the rim and drum.
the penguin spacer goes behind the backing plate. can be installed permanently in less than 30 minutes (assuming you inow what you're doing...), and dont damage/threaten the studs in any way. you can even go 13mm if you want
25 mm Wheel spacers Rnankoo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 03-22-2011 07:58 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
